Stock coil voltage?
Old Apr 26, 2007 | 10:20 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Stock coil voltage?
I tired to search and didn't find the exact answer I was looking for. Long story short, car would start fine then after a while it would stubble and shut off. So, pulled my Jacobs Ign. box and ultra coil off and starts up like a champ after I replaced all the sensors, etc before I tried this.
Anyways, how much voltages does the stock coil support? I had about 47,000 with the old setup and the new Jacob's are 60,000 volts but just curious how the stocker compared.
Is it 30,000 volts?
Old Apr 27, 2007 | 02:31 AM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
Re: Stock coil voltage?
if its in good condition, the external delco coil will put out 50+.
with the coil wire off they will easily fire down the tower to the laminations.
if i remember right, it takes around 22,000 volts to jump 1 inch, its about 2.5 inches to the laminations, so 22,000 times 2.5 comes to 55,000.
Old Apr 27, 2007 | 05:21 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
I believe the stock divorced coil only puts out 44000.
Old Apr 27, 2007 | 10:31 AM
Damon's Avatar
Irrelevant.
Voltage will only ever go as high as necessary to ionize the gas between the two spark plug electrodes. In a running engine that's almost never more than 15-20K volts even under highest load (WOT operation). Beyond that it's all about the total electrical energy in the coil how long it can keep that spark lit (measured in mili Joules, I believe).
In short, don't worry about the "voltage rating" of ANY of your ignition components EVER. It's completely irrelevant and misleading. The main thing is to diagnose what's gone screwy in your current ignition system. Whatever it is, the engine will instantly run better once you discover and correct the problem.
Old Apr 27, 2007 | 02:02 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Originally Posted by Damon
Irrelevant.
I'm not worried about it. Just would like to know....b/c I am testing AF ratios between the two so...info would be nice.
Its in good condition but about 17 years old.
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
TheExaminer
Aug 25, 2015 07:34 PM
Thirim
Aug 13, 2015 03:09 PM
