General valve cover questions
Old May 1, 2007 | 09:47 PM
ecetim's Avatar
Car: 92 RS B4C - needs lots of work!
Engine: 5.7L L98
Transmission: 700R4?
Looking to dress up the engine bay some and either get a slick looking set of silver or chrome valve covers. Down the road, I will likely replace the heads, intake, and cam on the L98. I'd imagine this will involve new rockers, push rods, etc.
Is there any consideration I should make towards valve cover selection with these goals in mind? I see there are standard height and tall valve covers?
Where can I find some decent silver or chrome ones for cheap? Prefer no cheesy logos or anything...
Old May 1, 2007 | 11:52 PM
1986Z28OWNER's Avatar
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
Re: General valve cover questions
go with the tall ones, typically roller rockers wont clear the shorter ones
Old May 2, 2007 | 07:54 PM
quisterio's Avatar
Car: 87' GTA
Engine: 350 L98 TPI
Transmission: 700-R4
Axle/Gears: 3.27 9-Bolt
From personally buying a set of chrome ones from Autozone, I would give anything to go back and get a different set because not even a year later, my chrome valve covers are starting to "Lose Their Luster" per say, from the heat.
Old May 2, 2007 | 08:14 PM
strokermotor91's Avatar
Car: 91 Camaro RS
Engine: Small Block
Transmission: TH350 w/ 3000 stall convertor
Axle/Gears: 3.73 w/ powertrax locker
chrome definately sucks hardcore. It looks absolutely amazing the first 6 months or so. Then it starts to rust and what not. But like mentioned above I would personally reccomend the tall valve covers, So in the future when you rebuild the motor or put roller rockers on the heads, You wont have to buy new valve covers
Old May 3, 2007 | 09:19 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Get tall cast aluminum.
Old May 3, 2007 | 09:55 AM
Magman's Avatar
Car: 1990 IROC-Z
Engine: 383 HSR
Axle/Gears: 3.70
Jegs has a set of Tall, Polished Aluminum ones for a decent price, I believe right at $100. Might check those out.
NBrehm
Aug 25, 2015 11:49 PM
db057
Aug 22, 2015 08:17 PM
1985chevydude
Aug 20, 2015 12:29 AM
blackd-out z28
Aug 15, 2015 08:18 PM
mustangman65_79
Aug 8, 2015 01:18 AM
