removng/installing injectors?
Old May 5, 2007 | 01:07 AM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
how does the injectors connect to the intake manifold. i know theres a clip on eahc injector for the fuel rail but as far as i can tell the injectors just sit in the intake holes and the o-rings is keeping it air tight.
but this cant be can it?
i want to replace my injectors and want to know how things are connecting before i take on this project.
Old May 5, 2007 | 10:15 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
Re: removng/installing injectors?
you pull the upper plenum off and unscrew the fuel rail, then you can pop the injectors out of the lower intake manifold, then slide the injector clips over on each injector at the fuel rail, then pop them out, installation is reverse. really not all that hard, i just did it in 40 minutes
Old May 5, 2007 | 11:47 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
That is correct.
Old May 5, 2007 | 01:19 PM
Bobby_80s's Avatar
Axle/Gears: no idea
ok thanks. any tips to ensure they won't leak? if i hear/feel the pop then the o-ring is making a good tight seal between the injector and fuel rail/mainifold?
Old May 6, 2007 | 08:56 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
If the o-rings are old just replace them. I've found that rubbing the o-rings with vaseline works much better for installation and removal then using the suggested light oil.
Old May 6, 2007 | 11:42 AM
Bobby_80s's Avatar
Axle/Gears: no idea
new injectors should come with new o-rings anyway right?
and are there any o-rings in the fuel rail where both ends of the pipe are side by side in front of the mainfold where they are screw tapped into fuel hose lines....any o-rings in those connections?
Old May 6, 2007 | 10:34 PM
Kevin 88's Avatar
Car: 88 Corvette
Engine: 400, AFR heads, ZZ9, SuperRam, 730
Transmission: Slushbox
Yes, new injectors usually come with o-rings and yes, all the connections to and from and in-between the fuel rail components have o-rings too.
Old May 18, 2007 | 09:38 PM
Bobby_80s's Avatar
Axle/Gears: no idea
to install/remove injectors is there a popping feeling/sound or how do you know its secure in the manifold and fuel rail?
i want to make sure since the clips dont fit on the ford injectors
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
