rear differential
rear differential
alright so the gears in the rearend of my camaro (86 iroc-z) went out on me the other day. the rearend i had in was positive traction with disk brakes. i decided not to rebuild the one i have when i found out the price (1500$) so i found a rearend out of a 87 iroc-z that's "slip resistant" and it has drum brakes. i know that you still have the same master cylinder with either drum or disk but i was wondering if it was possible to switch them over so i could keep the disk brakes. also wondering how much i'm gonna loose in the performance area since i'm not gonna have positive traction anymore?
Re: rear differential
No, you cannot use the same MC & PV for drums if you have the crappy cast-iron Saginaw calipers, as your 86 does unless someone has swapped a 90-up one into it.
Explain this about the gears "went out". They're usually pretty well secure in there; they don't often just "go out" like for a stroll or something.
"Positive traction" is just a different way to spell "slip resistant". No loss there.
ok well this is what happened... in detail.... i had been racing and playing around in the camaro cus that's what you do in a kickass car. so in the end the rear end went out when i say this i'm talking like gears got stripped, the front seal on it shattered, the back u-joint shattered, and the driveshaft was shoved about an inch and a half into the transmission. i was also able to move the drive shaft from left to right about 3 inches if not more. when i slowly drove it to the shop the gears kept slipping with what teeth were left on them. also to follow up on the whole using the same MC. it is the same one for drum or disk i asked the chevy house and they told me that the lines and everything are the exact same (which they are i already checked). i've heard from a few mechanic friends that i can just take the whole shaft and everything out from teh differential and slide them into the new(used) rear end as long as the gears on the ends of the shafts were ok.
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
the PV IS NOT THE SAME on the drum setups
that chevy house... LIED
you could reuse the axles as long as the you have the same spline carrier Ie 28, 26...and as long as they werent damaged
but i am confussed how do you "shatter" a U-joint and still drive the car?
but let me take a wild guess as to what you were doing when this happened...
5k drop with the e-brake on right...
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
If you don't know anything about cars, why wouldn't you? J/K...believe it or not I was a kid too...when I first started playing with high performance cars; those things happen when you don't realize all machines have relative limits. You should be able to keep the disc rear and get her back on the road for less than $1500.
Bill
Bill
actually it happened when i completely dusted a mustang getting on to interstate 20 after peeling out off the line at about 5000rpms then it all broke at about 145 mph... it sucked and i'm not new to cars i actually just finished rebuilding a moster 358 for my ford pickup.
Car: 1986 Camaro Z28
Engine: 400
Axle/Gears: 10 bolt Posi 3.73
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
red90IROCls1
Aug 25, 2015 06:56 AM
