So what temp do you run you camaro at?
Old May 10, 2007 | 09:08 PM
Chrome on Rust's Avatar
Car: 89 RS
Engine: 305 TBI
My car has always ran at about 180 but the when i put in a new thermostat it now runs at 220 that scares me could use a little imput on why? and what temp is a good one to run the car at?
Thanks for reading
(O its a 305 tbi stock)
Old May 10, 2007 | 10:40 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
195.
Old May 10, 2007 | 10:54 PM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
Re: So what temp do you run you camaro at?
i think you should put that old t-stat back in.. 220 is HOT.. 180 was probably the best.. its a good average.. my 385 runs at 165-70 on the road and can get up to 185 at the races.. when there is wind, its from tower side to spectator side.. pretty much parallel to the car.. or it comes from the back.. no action on the radiator in the staging lanes.. on those chilly nights (55ish) i can run 155 on the highway.. god i love that HUGE AL radiator..
Old May 12, 2007 | 11:50 PM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
Listen to 5-7-kid. Unless you have changed the chip (you didn't say what yr. your car is) to run with a cooler thermoustat (180* or lower) you will start getting a code 32 (EGR). What temp. stat did you put in? Have you replaced the radiator? Old radiators tend to plug up in the center of the core and a lower thermoustat will will stay open and not leave the coolant in the radiator long enough to cool off. Cooler thermoustat only applies to non computer engines unless the chip in a computerized engine is changed. A new radiator runs about 110.00 to 130.00 bucks.
Old May 13, 2007 | 12:13 AM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
I run a 180.
But then again im running something not even remotely close to a stock motor....
Old May 13, 2007 | 12:19 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Running a 160. When cruising around town in the summer (stop and go...etc) it runs around 175-180.
If I drive long enough with no stops, it will go down to 160. Never had a problem when it does, never threw any codes, and never seen any decrease in performance. But 95% of the time, the car is at 175-180.
Old May 13, 2007 | 10:16 AM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Originally Posted by 84z28350
I run a 180.
I'll echo that mine is far from stock non-computer controlled. The thermostat is a 180 but the temp is set by the cooling fans.
First comes on at 190 and second at 195. This way there is max coolant flow before the fans run. The idea is to run the fans as little a possible because the fans cost gas mileage and horsepower to run.
Above 55 mph the temp will drop to 180 because the air dam is supplying the air. This helps with heat "bloom" when you roll to a stop after a hard run and the temp climbs.
To further help with horsepower, I shut down the alternator at WOT so if the fans are on they get their power from the battery instead of the engine. A simple switch is good for 3+ horsepower at WOT and the engine stays cool .
Frozer!!!
Jan 19, 2024 04:55 PM
rocn7roc
Sep 21, 2021 02:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
pimp2303
Jul 27, 2017 02:03 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
