Call my mistake.
Old May 14, 2007 | 08:48 PM
stroker_SS's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Transmission: Th-350
Call my mistake.
I have been working on my newly rebuilt 355, I have just got everything on the motor to get it running.
Now the problem is that it backfires through the carb after running momentarily, and while it runs it mostly coughs and sputters. I've tried backing off the rockers, moving distributor, advancing-retarding. After everything it still runs like crap and backfires through the carb no matter where the distributor is set.
Old May 14, 2007 | 08:55 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: Call my mistake.
oh you have the plugwires screwed up
do i win something?
well that or you put the dist installed incorrectly or the cam isnt aligned with the crank properly
Old May 14, 2007 | 09:23 PM
stroker_SS's Avatar
Engine: 355
Uhh, no 18436572 thats where its set.
And cam is properly aligned dot to dot.
Old May 14, 2007 | 09:30 PM
Car: 91 RS
Engine: 350 vortec
well a back fire through the carb is a sign of one thing... intake valve being open when that cylinder is fired...
so you either have the plugs in the wrong order or you have the dist installed incorrectly... your pick when the cam and crank are aligned dot to dot the #6 cylinder is firing not #1 the dots at 12 will give you #1 firing
Old May 14, 2007 | 09:54 PM
wanta427's Avatar
Car: 1991 Z-28
Engine: 350 L98 al head Stealth Ram
Axle/Gears: 3.42 LS1 brakes
If you've got a flat tappet cam make sure you havn't wiped a lobe off the cam . If you didn't break the cam in and use good oil it's a real problem .
Old May 14, 2007 | 10:30 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I agree with this as being the first thing to check.
Old May 18, 2007 | 11:34 PM
stroker_SS's Avatar
Engine: 355
Update: I got the beast running today, broke in the cam, and took it for a spin. It was a real fun ride. Thanks for any advice offered.
I timed it wrong the first time around, pulled dizzy and timed it again, runs absolutely wonderfully. Starts with just a bump when cold, without a choke. I'm pretty proud of myself, being that i built that motor myself with a little help and a lot of research.
Old May 19, 2007 | 01:38 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Amazing feeling isn't it? Give yourself a pat on the back and go rip up the tires! Enjoy it while it lasts, soon enough you'll be breaking stuff, and the feeling won't last
How'd you get 9.7:1 CR with 882 heads, if I may ask?
Old May 20, 2007 | 01:03 PM
stroker_SS's Avatar
Engine: 355
I recalculated the compression ration and turns out it's closer to 9:0-1 but i'm just to lazy to change what it says.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
bschmale66853
Sep 30, 2015 08:11 PM
