LT1 Starter Q's
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
LT1 Starter Q's
Car is in need of a new starter I think. When its cold it will "start to grab" then slips. After about 3-4 trys it grabs n starts. When its warm, it hits first try.
Anyway, I did some searching and some of you have put LT1 starters on because they are smaller, lighter, gear reduction. Then I started searching part numbers and different years took different starters. Which one is it I need? From readings, no modifications necessary, just direct bolt?
93-94 10465143
95-97 10465293
98-02 (ls1, anyone tryed it?)10465385
93-94 10465143
95-97 10465293
Re: LT1 Starter Q's
Doesn't matter; they're all the same, functionally.
Yes, it's a direct fit.
I don't think the LS1 one will work.
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: LT1 Starter Q's
I don't know what the physical difference is between the '93-94 and '95-97 starters, but the '95-97 was the years they changed to a dual cat setup, so that may have something to do with it??
Car: 1991 B4C Camaro RS
Engine: 370 lsx ls3 heads victor jr w/carb
Transmission: TH400 w/brake coan 8"4500-4800 stal
Axle/Gears: Moser 9" locker w/ 4.11's
Re: LT1 Starter Q's
there is a difference in the 2 lt1 starters... i had 2 go to autozone and look at the 2 in person.... and compare 2 my old one....
Re: LT1 Starter Q's
The blocks are the same, the flywheels are the same, the BHs are the same, the batery cables are the same, the ignition switch is the same. In short, everything the starter touches in the different years, is the same.
Even if the 2 (or however many) models of starter are different to the eye, they will both work; either on any year of LT1, or on a suitably equipped earlier motor as well.
Engine: 350 S-TPI
Re: LT1 Starter Q's
I just found the bolt thing, as well that was posted on here(read that after I saw online other place).
Anyone know what bolt length(s) and thread-pitch is needed?
I'm seeing prices anywhere from 59 to close to 200 for starters.
Car: 1989 IROC
Axle/Gears: 3:23 Torsen 4th gen rear
Re: LT1 Starter Q's
I just finished gettting mine in. I did have to shim it some to space it away from the fly wheel was too "tight". So there is some tweaking involved
Engine: 350 S-TPI
Re: LT1 Starter Q's
correct bolts? I need to place an order for other things as well
http://store.summitracing.com/partde...5&autoview=sku
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Re: LT1 Starter Q's
Does one of the 2 part numbered starters (93-94) (95-97) have more torque or gear reduction then the other? if there both the same why are there two different part numbers? why didn't GM stick with one? theres gotta be a reason?
Gunner242
Dec 25, 2015 04:49 PM
