need help
Old May 16, 2007 | 05:16 PM
Jaime3670's Avatar
need help
my car started making this weird noise on sunday and im not sure what it is
some people were telling me that i could be a rod bearing
can u guys help me?
i posted a video below of the sound
http://s69.photobucket.com/albums/i7...MOV00104-1.flv
thanks for your help
sorry wrong video
this one is correct
http://s69.photobucket.com/albums/i7...t=MOV00104.flv
Old May 16, 2007 | 06:19 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
Take the accessory belt off and try it again. If the sound goes away, it's one of your accessories.
Sounds a whole bunch like what my 3800 Buick sounded like when the harmonic damper crapped out. But, I'm not sure what type of damper the 3rd gen 2.8's use.
Could be a main bearing, doesn't really sound like a rod bearing, though.
Old May 16, 2007 | 06:45 PM
Jaime3670's Avatar
Re: need help
you are talking about the main belt right?
i dont know a lot about cars but im going to try that tomorrow,
one of my friends also told me to take off the valve covers and check the rockers. hopefully one of those two will fix the problem
Old May 16, 2007 | 07:15 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: need help
Take a long handled screwdriver, place the plastic end against your ear, and hold the metal end against any location - when you find the spot with the noise, you'll know it! The screwdriver picks up vibrations and they are magnified 10 fold when you have it against your ear - that will give you a place to start. I did this when I had an accessory making noise - this allowed me to know for sure it was my AIR pump and not my A/C.
Old May 16, 2007 | 07:58 PM
Corky's Avatar
Car: 88 Firebird - SOLD!
Engine: 2.8L
Re: need help
Yikes! not good. Since the engine doesn't seem to be running bad - skipping, rough idle etc, I'd eliminate valve train. Sounds like a rod to me. Not too loud when your camera was around topside of the engine, but when you shut the hood with camera in front of car it sure sounded louder and deeper like a rod knock.
You can pull wire or short out cylinders one by one to isolate the cylinder. When you find the cylinder the sound will get a lot lower or virtually go away. Sounds like you'll be into this motor. Any thing funky happen leading up to the noise?
Corky
Old May 16, 2007 | 10:43 PM
five7kid's Avatar
It was more of a constant "knock-knock-knock" like it made the knock with each engine revolution; rather than the "knocka-knocka-knocka" - which is louder for one revolution than the next, for a rod knock.
But, could be a rod bearing. Pretty common with those engines.
Old May 17, 2007 | 12:48 AM
Jaime3670's Avatar
Re: need help
Corky
i dont think anything lead to this ive had the car for about 1 month and almost not driven it at all
i just hope its something mot too expensive
Old May 17, 2007 | 05:13 AM
Corky's Avatar
Engine: 2.8L
Re: need help
Five7Kid above has got a good point, it does kind of have a "baseball card in the spokes" sound to it (I'm dating myself here). Come to think of it, about 4 months ago I had a neighbor bring me her '01 Blazer. She was told the engine was shot - had a rod knock. I pulled out my 30yr old stethascope and found the noise coming from the distributor. The rotor shaft had at least a 1/2" side play in it. So, it wouldn't hurt to pull you dist cap and check for play in the rotor shaft, or invest in an automotive stethascope to pinpoint the source of your noise.
BTW - how many miles on the engine?
Corky
Old May 17, 2007 | 05:14 PM
Jaime3670's Avatar
Re: need help
i believe it has over 215,000
but not sure because the miles were disconnected and the last number it read was like 21x,xxx so probably around 200,000-240,000
the engine is old i think uim probably going to sell the car because im saving up for an LS1
how much do u think the car is worth? like that
Old May 18, 2007 | 05:47 PM
Jaime3670's Avatar
Re: need help
do u guys think i can sell the car for like $700
or thats too much?
