Please help me identify this!
Car: 1989 irocz convert
Engine: 383 tpi
Transmission: 4 spd auto
This bracket/vacuum thing is bolted under my ignition coil. I know there is a wiring harness that snaps into the top female electrical connector but what i do not know is if the bottom male piece is supposed to get a vacuum line???
Please feel free to throw any 2 cents in on this. Any help would be greatly appreciated!!
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
Re: Please help me identify this!
I dont know if this is the proper term, but I think
its the EGR solenoid. The vacuum fittings attach to
the EGR valve on the intake manifold and one to
the vacuum ports on the intake plenum.
There is a electrical connector breaks off
the main harness that wraps around and
behind the engine.
I just left mine hidden, dangling out of the way.
behind the engine.
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
TPI is correct.
Nothing gets attached to that nipple between the prongs. There is actually supposed to be some foam/filter there.
Engine: 383 tpi
Linson
Sep 21, 2015 01:08 PM
