tick tick tick
Old May 18, 2007 | 08:20 PM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
tick tick tick
Alright, the engine has got a ticking noise now and the oil pressure (or at least the gauge) is screwy. First starting it up it is at 45 psi. After about 5 minutes or so it makes it way to 40 and slowly goes all the way down to about 10 psi. (by the way all the psi's at at idle) Yet when I accelerated the psi went back up to 45psi and held until i let off the accelerator.
Now back to the ticking, the 1.6 RR ticked but werent THIS loud. I dont know if its valve tick or lifter tick or something else completely. Suggestions? Symptons or either?
Oh yeah one more thing......the day before i noticed the extra ticking noise, the car cut off on me 3 times at idle while at operating temperature.
Old May 19, 2007 | 12:27 PM
Car: 92 Camaro
Axle/Gears: S60 373
Re: tick tick tick
somebody help me out here im pullin what lil bit of hair i have out!
Old May 19, 2007 | 01:22 PM
SPIKE's Avatar
Car: 86 CAMARO
Engine: 92-350 +.030
Transmission: 86-th400
Re: tick tick tick
can you rig up a temporary oil pressure gauge? oil pump might be crappin out ? not enough oil gettin to the valve train and ampliflying the ticking ?
Old May 19, 2007 | 02:16 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Re: tick tick tick
You should get a stethoscope or a piece of garden hose and see if you can isolate where the ticking is coming from. Although the oil pressure could be a bad sign. I am 99% sure I spun a rod bearing, and my symptoms started out just like yours. Pressure starts high, but dips down to 5-10 psi. My ticking was really soft at first, could have been mistaken for an exhaust leak, but now its much worse and sounds like someone is shaking marbles around in a coffee can.
I'd hate to jump to the worse case scenario, but I suggest you start saving money.
Old May 19, 2007 | 04:48 PM
Car: 92 Camaro
Axle/Gears: S60 373
Re: tick tick tick
i just spun a road bearing on this engine in Dec.....this is the rebuilt. i dont think its the rod bearing. i had massive oil leaks and the sound was different. is 15-20 psi ok for idle?
Old May 20, 2007 | 01:11 PM
Car: 92 Camaro
Axle/Gears: S60 373
Re: tick tick tick
sounds like coming from cylinder 1......
Old May 20, 2007 | 10:04 PM
Re: tick tick tick
People say that 10psi per 1000rpm is sufficient, so for idle, you should be alright. Although that is still too low for my liking, I have always been used to the needle never dropping below 30psi.
You say it is coming from cylinder 1, do you hear the sound better at the top of the cylinder at the head, or down where the crank should be? If it is coming from the top, I would pull the valve covers and see if you have an inner valve spring that has broken, or crank the motor over and see if there are any loose rockers.
Old May 26, 2007 | 08:03 PM
Car: 92 Camaro
Axle/Gears: S60 373
Re: tick tick tick
i figured it out!! it is the air pump.....
Old May 26, 2007 | 08:28 PM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
Re: tick tick tick
Atleast it wasent anything major.
Old May 27, 2007 | 07:58 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
Re: tick tick tick
how would the air pump give ticking noise neat the valves?
near the valves i mean
Old May 28, 2007 | 06:51 PM
Car: 92 Camaro
Axle/Gears: S60 373
Re: tick tick tick
i didnt get the hose and listen to it i just kinda guessed and i listened more carefully and then took the belt off...and no more ticking......i feel like a dumb*** but hey i can live with an annoying tickin until i can rip out all my emission stuff..
david068513
LSX and LTX Parts
Nov 15, 2015 11:37 PM
meeklay812
Oct 1, 2015 03:46 PM
corey8084
Sep 17, 2015 02:56 PM
david068513
Sep 13, 2015 11:24 AM
david068513
South East Region
