losses power over 4000 rpm
Old May 22, 2007 | 12:04 PM
intex1982's Avatar
Car: 89 formula/00 z28
Engine: carbed 350/ls1
Transmission: 700r4/ a4
Axle/Gears: 3.23 posi/ 3.73 posi
my new motor pull great wot to 4000 rpm and seem to fall off fast. what could be making it losses power over 4000 rpm?
Old May 22, 2007 | 12:43 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Re: losses power over 4000 rpm
Have you touched that carb yet? timing? hows the fuel system?
Old May 22, 2007 | 02:13 PM
intex1982's Avatar
what do i need to do to the carb i changed the spring and the fuel system is a stock tpi fuel pump in the tank reg. at 4psi and new filters. timing i really dont understand on my car how to really set it bc it runs best set at 50
Old May 22, 2007 | 03:49 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Jack up the fuel pressure and knock that timing back, alot...
Somethings wrong if you need 50* adv to have it run decent! Is this initial or 'all in' ??
Depending on the actual cam it should probably need about 10-15* initial but still hit the usual 36* max adv
Old May 22, 2007 | 05:10 PM
intex1982's Avatar
ok i cant get the timing down i tryed! i need to tune the vac adv thing on the dist. its pulling 35 deg. adv on 15 so it has 50 deg.total at 3000 rpm
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
theshackle
Sep 17, 2020 08:26 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Bradsaundry
Aug 12, 2015 12:34 AM
