Help speedo wont work
Old May 23, 2007 | 01:25 PM
dlvalure's Avatar
Car: camaro rs (a tru sleeper)
Transmission: turbo 350
i hav a 1992 camaro rs with a TH350 tranny....this is how i bought the car but for sum odd reason the speedo wont work...the rpm gauge works if neone has ne ideas please help
Old May 23, 2007 | 02:06 PM
gibsongod716's Avatar
Car: 85 Trans Am / 64 Chevy Nova
Engine: Turbocharged 355ci / 383ci
Transmission: WC T-5 / T10
Axle/Gears: 3.45 / 4.11
Re: Help speedo wont work
what exactly do you mean it wont work?
does it move at all, or does it make an attempt to move?
it could be a loose speedometer cable, or maybe a short somewhere in the cluster, the transmission might have a problem....theres many things, I(we) just need a little more info
Old May 23, 2007 | 02:24 PM
dlvalure's Avatar
my car is electric not cable driven i need to no how to make that conversion the original tranny dat belonged in the car was a 700r4 now its a th350
Old May 24, 2007 | 07:10 PM
iroczracer07's Avatar
Car: 1989 Camaro
Engine: 350 but it's torn down right now.
Axle/Gears: I'm working on it,lol.
I hate to break this to you, but if you have a th350 it's cable driven. If the 700r4 had a vehicle speed sensor before and that was just plugged into the th350 then you've already found your problem. You need a speedometer that is cable driven, a speedometer cable, and the correct speedometer gear and housing that originally came with the th350.
Old May 24, 2007 | 08:35 PM
2kflhr's Avatar
Car: '68 396 SS/RS, '02 SS
Thats going to be aggravating!
Option #2
Buy a GPS and mount it on the dash panel above the radio/console bezel. At least you could get your MPH and miles driven. I had the speedo go out in a Honda beater I bought for commuting back and forth to work (not much to look at but 32 mpg is great) and used a small GPS until I got it fixed.
Old May 25, 2007 | 08:58 PM
Car: 1989 Camaro
Option #2
Not a bad temporary fix. I commend you on your ingenuity. I wouldn't have thought of that.
Old May 25, 2007 | 09:20 PM
2kflhr's Avatar
I bought one 6-7 yrs. ago for when I take my jet-ski out onto a big lake down in SC. It has a odometer, tripometer and speed in several different style displays. Only draw back is it takes it a minute or so to locate the satellites.
Old May 26, 2007 | 08:28 AM
Car: 1989 Camaro
Who cares about the drawback. That's just cool.
Jorlain
Aug 24, 2022 05:11 PM
Jeremys87
Jul 14, 2022 09:08 PM
Wade787b
Sep 29, 2015 01:15 PM
Irocohio
Aug 12, 2015 08:03 AM
beachrodder
Aug 7, 2015 04:27 PM
