2.02 heads need info!!!!!
Old May 24, 2007 | 12:50 AM
transam360's Avatar
Car: 1986 caged out firebird
Engine: 454 = wheelies
Transmission: th400 stall and trans brake
Axle/Gears: 4:11 ford 9" with ladder bars
what years of cars and what model cars have 2.02 heads i am lookin at goin to the junk yard and findin a pair and buildin them up if anyone has this info that would be great thanks Eric
Old May 24, 2007 | 02:27 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Various and sundry.
You'd be better off looking for good heads.
Old May 24, 2007 | 07:03 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: 2.02 heads need info!!!!!
It sounds like you don't really know anything about cylinder heads (not to be rude).
Valve size is a very small piece of the puzzle. I could have 1.84" valves in some vortecs (with new valve seats), and blow the doors off some old 882 heads with 2.02 valves, for example.
There aren't many factory casting cylinder heads worth using. From what i've seen;
1) Vortecs
2) Fuelie/double hump (since those are about as common as Ferrari's in JY's this is almost a moot point)
3) 601/416/081 305 heads from the mid '80s. Port them up and you're laughing.
4) TBI heads, 187/193 castings. For a low RPM motor they're quite good, excellent swirl. Not great for high RPM high flow type of engines.
5) All the other garbage smog heads; 882, 993, etc etc
Old May 25, 2007 | 02:01 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Only the very high performance optional motors from Muscles cars fo the 60's and early 70's came with 2.02's. the last car to have 2.02's would be the 1973 L-82 Corvette/Z28 245hp/350.
You are not likely to find a set of 2.02 factory heads laying around in a Junk yard.
There are a few jewels to watch for . 1996 to 2000 GM L31 Vortec 350 truck heads. Casting # end in 062 or 906. All others are not vortecs.
If you want a half decent head that you can take home and port up using big valves look for the "416" 305 HO heads or maybe a "601" 305 head. or the heads from a Camaro/Fbird 305TPI or 350TPI motor "081" or "083" castings. Aluminum version "113" Every thing else is not worth picking up. If it has a throttle body injection TBI leave the heads.
Old May 27, 2007 | 01:24 PM
transam360's Avatar
ok so today i couldent find any 202s so i talked with one of my friends and he had a rebuilt set of 1997 vortec heads so i bought them for $75 was that a good deal and are they good heads
Old May 27, 2007 | 01:29 PM
Sonix's Avatar
Car: 1982 Trans-Am
Yea, heck that's a great deal.
Time to find out how good of a friend he really is - what's the casting number on them?
If they're really vortecs, now you've gotta go find a vortec intake manifold.
Old Jun 11, 2007 | 02:28 AM
transam360's Avatar
ok is this casting number good it is a 98 vortec head the number is 12558062
Old Jun 11, 2007 | 12:53 PM
five7kid's Avatar
That's the "062" head F-BIRD'88 was talking about.
And an example of a "good" head I was talking about.
They require a Vortec intake manifold (the stock factory system isn't very good for performance). Can we assume you're going to us a carburetor?
Old Jun 11, 2007 | 02:35 PM
transam360's Avatar
i went with a high rise air gap single plane intake with a 750 carb and a 510 int and 533 es
Old Jun 11, 2007 | 05:16 PM
five7kid's Avatar
The heads will need to be modified to take that much lift. New valve springs, guides cut, etc. With that much lift, screw-in or pinned rocker studs would be a very good idea.
Cornholio7979
Sep 20, 2018 02:31 AM
509 camaro fan
Sep 6, 2015 10:43 AM
ambainb
Aug 29, 2015 12:43 AM
89mulletbird
Aug 12, 2015 07:08 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
