my engine only knocks at 2500 RPM why?
Old May 27, 2007 | 05:02 PM
83camarokid's Avatar
Car: 83 Camaro Z/28
Engine: GM Goodwrench 350
Transmission: 5-speed
I have a 83 Camaro that has a GM Goodwrench 350 crate engine and it now knocks at 2500 rpm and i have no clue why....any help would be awsome
Old May 27, 2007 | 07:55 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome to thirdgen.org.
Did you keep the stock carb and distributor? Is your EGR valve working?
Old May 28, 2007 | 12:03 AM
Car: 83 Camaro Z/28
Re: my engine only knocks at 2500 RPM why?
it has a rodchester quadrajet and im not sure on the distributor i have a couple of bad wires though (found them today)
Old May 28, 2007 | 01:11 AM
five7kid's Avatar
If the carb and distributor are stock, then that's good. If either but not both has been replaced with a non-computer type, that's bad.
Bad wires can cause some weird problems.
Old May 28, 2007 | 01:26 AM
youhadnochance's Avatar
Car: 1989 camaro
Engine: 383
Transmission: t5
Axle/Gears: 10 bolt 308
I had a simmular problem I think.Does it only knock at 2500 and stop at higher rpms?If so when I pulled my motor I found the bearings were down to the copper on the rod bearing.It would only knock around 3000rpm or so but not above or below that.The motor only had about 1000 miles on it too.
Old May 28, 2007 | 01:36 AM
Car: 83 Camaro Z/28
it will knock only when i have the gas pedal down more than a quarter of the way if not i can go through all the way to 4500 and no problem if i put it all the way down to the floorboard it knocks bad on only let me go to 3000 and thats it...i noticed that it struggles when its floorboared and not when im bearly on it
db057
Aug 22, 2015 08:17 PM
TreDeClaw
Aug 14, 2015 06:58 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
gwade12
Aug 8, 2015 08:17 AM
