New Battery, now won't ilde right!? HELP!
Old May 28, 2007 | 10:12 AM
killerklown's Avatar
Car: 1990 Firebird
Engine: 3.1
Got a new battery for my 90 bird 3.1 V6, I know you need to drive it a bit so the comp gets used to the new battery, BUT its been 130 miles already and it idles fine in park//neutral. However when in gear at a stop light it will stall, just as im hitting the brakes the rpms will drop, tries to adjust itself, but will stall unless i keep my foot on the gas and brake at the same time. Before the new batt, it was fine.
-also put super unleaded gas in it w/octane booster to clean//wake it up. didnt do much in that dept so far. could that be the prob as well??
-other than the idle problem it runs smooth, volts are right, and temp it right.
-also checked the vac lines, appears to be ok.
ANY help would be appreciated!
Old May 28, 2007 | 11:08 AM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Re: New Battery, now won't ilde right!? HELP!
Originally Posted by killerklown
Got a new battery for my 90 bird 3.1 V6, I know you need to drive it a bit so the comp gets used to the new battery, BUT its been 130 miles already and it idles fine in park//neutral... Before the new batt, it was fine.
This is common. It takes a while for the ECM to "re-learn" the engine. When the battery was disconnected the ECM lost it's changes it made over time to run the engine correctly. It learns a little at a time per key-on cycle. If you make one long run on one key cycle it only made and saved a small change. Give it a chance to re-learn the engine in stop and go driving. Turn it off for 30 seconds and restart it will speed up the process. The gas won't make a big difference unless you put in way too much booster.
Old May 28, 2007 | 11:40 AM
Car: 1990 Firebird
Engine: 3.1
thanks for the help, this happened before in this car when i disc the batt, but it didnt take this long. Ill give it some more time and do what you said.
-Seems ridiculas that it takes this long just because of a new batt. Although when i replaced the batt in my 4th gen ws6, everything went chaos for a day or so.
-this stalling just gets on my nerves something terrible!
Old May 28, 2007 | 08:58 PM
Car: 1990 Firebird
Engine: 3.1
Well, she is acting ok and normal again. Drove it, shut it off, started it up and so on. Took a while though, sheeeezzzz! Heaven forbid you disconnect your battery on these cars....
Old May 28, 2007 | 10:02 PM
Engine: 350 4BBL
Hell, I just hate reprogramming all those radio presets.
Old May 28, 2007 | 10:05 PM
Car: 1990 Firebird
Engine: 3.1
Tell me about it!
camarohelp
Sep 22, 2015 03:19 PM
Johnoooooo
Sep 22, 2015 08:55 AM
sahlomonic
Sep 20, 2015 07:15 PM
gta892000
Sep 16, 2015 12:37 AM
Formula_88AE
Sep 3, 2015 01:47 PM
