what heads does an lg4 have
Car: 89 formula/00 z28
Engine: carbed 350/ls1
Transmission: 700r4/ a4
Axle/Gears: 3.23 posi/ 3.73 posi
what heads do a lg4 have. it is in a 85 trans am 8th vin h
Transmission: 4L80E/4L80E
416 castings. Pretty good place to start, as far as factory heads go.
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Re: what heads do a lg4 have
if done right, the 416s can flow some pretty amazing numbers. But you have to be willing to put alot of time and effort into them and hope to hell you dont mess up on the last port!!!
Car: 88 IROCZ 350
Engine: 355 cu TPI
Transmission: 4L60 w/ 3200 stall
Axle/Gears: 9 bolt W/370 gear
up to 80 more horse. Joined: Mar 2000
Depends upon your objectives.
A little more information regarding what's behind the question is in order before blanket statements like "junk" and "80 HP" are made.
Car: 88 IROCZ 350
Engine: 355 cu TPI
Don't wait your money on Junk 305 Heads!!!
Still don't know why the question was asked. If building a daily driver that will never see the track, not much sense in spending $1500 on aftermarket heads.
Car: 88 IROCZ 350
Engine: 355 cu TPI
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
How much money do you have to spend on getting old heads clean and inspected? Plus a good valve job, maybe new valves, new valve guides, springs retainers and keepers. Maybe a mild port job? It will add up very quick. You can get a pair of Edelbrock performer heads from Jegs for just under a grand and this will make you feel like you have a new car.
How fast is your car with the expensive aftermarket heads?
Car: 88 IROCZ 350
Engine: 355 cu TPI
Engine: 383 Carb
Transmission: 4L60
I could find a receipt to post if you like. The machining involved in rebuild a head is by no means complicated or labour intensive, so why do you think it should be expensive? Porting is labour intensive, but it's something that most people would prefer to do themselves.
Car: 88 IROCZ 350
Engine: 355 cu TPI
Yeah right and you are selling beach front property in Arizona right...
So let me get this straight, you can build junk heads with new valve guides, new stainless 2.02 and 1.60 valves, new seals, three angle valve job on new seats, new double Valve springs, new retainers and new keepers plus the the port job to make them flow as good as the Edelbrock ones for only $460.
Did the porting and drill and pin rocker studs myself. Flowtested by a buddy on a real flow bench at 232cfm@28". Never been to Arizona
Car: 84 Z28
Engine: 357
Axle/Gears: 3.43
Wow, someone needs to open their eyes...
As long as your local machine shop isnt a bunch of crooks you can build yourself a good set of heads out of the 416 castings, and all for alot less than a set of new heads!
Certinately though, if you want/need a real badazz set of heads go aftermarket. But most of the time you dont need a $2000 set of aftermarket heads to feed a mild little backyard buildup and a set of modified factory heads are more than adequate.
My machinest does the pair for $150 if you dissasemble them. And he is one of the best in town. But this is just NEW Mexico so I dunno.
Car: 88 IROCZ 350
Engine: 355 cu TPI
Lets see, a minimum rebuild will have a three angle valve job on the intake and exhaust valves, plus if you did not know GM uses hardening process on the exhaust seats that only leaves a thin hard surface on them, so when you do a valve job the hard surfuce is gone. That leaves you with a soft exhaust seat, so it should be replaced. You also need new seals, new springs, new retainers and new keepers because we all know that the factory ones are weak and after 22 years they are definitely worn out. Oh, I forgot the valve guides. All that for $150.
I don't know what type of rebuild you are talking about but it sounds like maybe you went to Mexico rather than New Mexico! Are you selling beachfront property over there, too?
Car: 1983 G20 Chevy
Transmission: 4L60
First it was $100, now $150 for a rebuild on a pair of junk heads.
Valve Jobs ARE cheap, SBC valve train parts are cheap, get over it.
Car: GTA
Engine: 383 HSR
Transmission: TH-700R4
Just to put things in perspective. Things are ALWAYS cheaper when you supply your own parts.
A mind is like a parachute, works best when open.
Please consider the alternatives before you open your mouth and remove all doubt.
Car: 1983 G20 Chevy
Transmission: 4L60
Just because you do not pocess the intelligence to shop around does not mean no one else does. Not everyone wants aluminum heads either.
ask ??????? because my brother got a trans am for 350.00 and we was going to fix it up cheap.just to play with. nothing he really want to sink much money in.
Well, the LG4 doesn't have Vortec heads, and the originator has come back to answer the question why he asked, and that is limited to "fix it up cheap.just to play with. nothing ... to sink much money in", so let's keep the discussion to that.
Understood? No arguments, no "my dad can beat up your dad" stuff.
. Thread
92projectcamaro
Jan 18, 2016 08:00 AM
New2Chevy
Sep 28, 2015 12:35 AM
