Re-Use Steel Shim Head Gaskets?
Old Jun 9, 2007 | 12:33 AM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
I think I already know the answer to this, but I have a set of Fel Pro steel shim head gaskets installed (FP-1094) and am swapping short blocks. Can these be reused or should I get new ones?
Old Jun 9, 2007 | 01:34 AM
ResurrectingZ's Avatar
Car: 1987 IROC 1991 RS
Engine: 5.7 TPI 5.0 TBI
Transmission: T-5 , 700R4
Axle/Gears: 2.73 twice
Re: Re-Use Steel Shim Head Gaskets?
I prefer new head gaskets every time I swap heads. I figure its less trouble to do it and get it sealed right every time. Unless its a go-cart. Then every used head gasket is a good gasket.
Old Jun 9, 2007 | 06:23 AM
You ABSOLUTELY MUST get new ones; even if they've only been torqued down and not run. Those are bad enough about leaking even when they're new.
Old Jun 9, 2007 | 07:14 AM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
they're only like $20 each.. why save $40 bucks and risk spending $800 to rebuild the motor?? cheap insurance.. change everytime..
Old Jun 9, 2007 | 03:46 PM
Like I said, I pretty much knew what was coming, but thank you all for confirming what I thought. Yeah I wasn't sure whether or not they were reusable because they were steel shims. I'll be getting a Fel Pro performance gasket kit and use those gaskets.
3rd gen money
Sep 8, 2015 11:40 PM
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
