what do you guys think about this combo?????
Old Jun 13, 2007 | 08:24 PM
FastEddiesIROC's Avatar
Here's my motor combination, tell me what you guys think how much HP i was making
Bowtie block 4.155 bore
callies crank 3.75 stroke
Lunati Rods
Wiseco Pistons 10CC dome
AFR 210 CC 74cc heads 2.080 intake 1.600 exaust
Victor JR intake
750 DP with proform carb body
Accell HEI distributor
1 3/4 long tube headers 2 1/2 pipe flowmaster mufflers True Dual
1.5 Comp cams roller tip magnum rocker arms
And here is my cam spec sheet
http://www.crower.com/misc/cam_spec/...00322&x=37&y=4
Also tell me if this cam is good enough for this engine and what would be better if anything.....Any input would be awesome
Old Jun 13, 2007 | 09:05 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: what do you guys think about this combo?????
I assume that is a solid roller cam? With those heads maybe go to a 1.6rr. The heads are most likely good to .600" lift. Might want to talk things over with Crower.
Old Jun 13, 2007 | 11:39 PM
Solid flat tappet
Old Jun 14, 2007 | 07:02 AM
Not enough cam; not enough rocker.
The heads can't do their job if you've got all this gigantic intake port, and down at the very end of it, there's this valve that just barely gets cracked open. "The point" of having heads with large ports, is FLOW.
That cam is listed in the Crower catalog as a street cam, "high revving .... small c.i.d. engines". Even though all you've got is a 400, not a particularly large engine at all, it still sounds like a mismatch to me.
Instead, look at their 00312, 00313 or 00316 grinds; note the rocker ratio specs for those; and use ROLLER rockers. The Crower steel ones would be excellent, or the Comp steel ones. I would not use ANY kind of ball-fulcrum rocker with as much spring as those heads have; and I would not use aluminum rockers if it will see any street time.
Old Jun 14, 2007 | 09:06 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
As far as bang for the buck on a high quality rocker arm, the Pro Mags are hard to beat.
Old Jun 14, 2007 | 05:00 PM
I see what you mean, what i dont understand is why would the guy who built this motor would sink all this money in to it and skimp on the cam?? Would it be a good Idea to stick with a solid flat tappet or switch to a solid roller? I was already looking in to the comp cams pro magnum rockers. Now, being that my pistons have a 10 cc dome, think with more lift my valves can hit the pistons??
Old Jun 14, 2007 | 09:51 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Solid rollers are the way to go if you plan on spinning high RPM's. However, the equipment to run them properly costs a pretty penny. Good solid roller lifters are in the 3-4 hundred range, good springs can run upwards of 2-300, same price range for the camshaft. The list goes on. It's not cheap to run SR's correctly.
The only way to know if you'll have VP clearance issues is to dummy it all up and find out.
customblackbird
Aug 15, 2021 10:16 PM
1984HO
Mar 19, 2021 11:59 AM
IMissMy86TA
Aug 31, 2015 08:40 PM
nuggie
Aug 25, 2015 01:27 PM
Street Lethal
Aug 14, 2015 08:25 PM
