what shoulod i set my timing to?
Old Jun 18, 2007 | 07:52 PM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
i have an 84 camaro 305. gna be putting on an edelbrock 600cfm carb with vaccum advance dist. what do i set my timing at? stock settings or do i got to advance the timing? also my rear heaer tube passenger side is glowing red. wtf would cause that? thanks
Old Jun 18, 2007 | 10:44 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Re: what shoulod i set my timing to?
If you ave only one glowing exhaust tube, the intake port on taht cylinder is lean ( vacuum leak)
Set the timing with a advance timing light and vac adv disconnected to 32-36deg BTDC at max rpm advance. Vacuum advance should add an additional 12-15deg at part throttle high speed cruise. Total combined mechnical+vac advacne should not exceed 51deg.
Old Jun 19, 2007 | 06:45 PM
Engine: 355
thanks on the timing issue. but where would i have a vaccum leak just for that cylinder?
Old Jun 19, 2007 | 07:12 PM
F-BIRD'88's Avatar
The gasket between the intake manifold and cylinder head.
Or what ever you have connected to the vacuum port that is on top if the #8 intake runner is leaking.
(transmission vacuum modulator or attaching line)
Old Jun 19, 2007 | 08:30 PM
Engine: 355
it only started glowing when i put on a quadrajet 800 cfm carb. would that be part of the glowing problem too? the intake is tight and dont hear or feel any leaking around it. i dont see any lines runnin to the cylinder 8... im lost
Old Jun 20, 2007 | 12:05 AM
1320_Guy's Avatar
Car: 89 RS
Transmission: th350
There should be a vaccume port right behind the carb in the #8 intake runner. Check all the vaccume lines that connect to that port.
Old Jun 20, 2007 | 07:46 PM
Engine: 355
i dont k
now what port thing your talking about??? on back of carb theres a steel line connection and a vaccum line its connected to carb.. wheres it go to after that?
Old Jun 20, 2007 | 08:48 PM
F-BIRD'88's Avatar
If you could see or hear the manifold vacuum leak you would not be typing here . You'd be out changing the gasket. Check the carb base gasket. the intake manifold could still be leaking from the bottom. Use some propane down the carb while its running. Does the exhaust pipe stop glowing when you add the extra fuel?
Old Jun 20, 2007 | 09:01 PM
Engine: 355
i had a quadrajet 800 cfm on there. i wrote here thinking it might be an issue for the problem... extra gas it floods itself out. and the pipe only gloew red when i put this carb on. could that be an issue? i was thinking maybe the gasket on top of my carb spacer could of been leaking, but not sure
Old Jun 21, 2007 | 07:04 PM
Engine: 355
also do i need to unplug anything to do ainitial timing? the connector i saw sumbody say but where is it? thanks sorry im a dir da dir
specialized
Jun 18, 2022 09:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Andrew6.688
Dec 13, 2015 10:59 AM
