76cc heads
Old Jun 19, 2007 | 06:37 PM
icemanohio69's Avatar
Car: 2000 xtreme
Engine: 4.3L
76cc heads
what should i look for truck,car or what for 76cc center bolt heads and what casting numbers do i look for
thanks
Old Jun 19, 2007 | 08:23 PM
Damon's Avatar
Re: 76cc heads
hmmmmmmm..... I'm not entirely sure they made 76cc centerbolt heads. While 76cc was very common in the 70s and early 80s when they were still using perimeter bolt heads I'm not sure if they ever made a centerbolt head (87-up) with chambers that large. Not sure though. I'm sure somebody else will chime in.
Old Jun 19, 2007 | 10:33 PM
online170's Avatar
Car: 1987 Firebird
Engine: 355
Re: 76cc heads
check on mortec chevy home page. You'll find what you need there.
Old Jun 19, 2007 | 11:11 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: 76cc heads
There were no good factory 76cc heads anyway
You want low compression with your flat tops for use with a blower?
I'd say aftermarket time.
Old Jun 20, 2007 | 03:31 PM
Car: 2000 xtreme
Engine: 4.3L
Re: 76cc heads
my uncle gave me a 383 that he used in a circle track car i plan on putting it in a 1988 3/4 ton gmc 4x4 but i has dome pistons i need to lower the compression for pump gas i would like to use the tbi fuel injection with mods holley tbi and custom chip any ideas? thanks for replys
Old Jun 20, 2007 | 03:45 PM
shaggy56's Avatar
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
Re: 76cc heads
I think you are better off looking for some aftermarket heads. They sell some affordable aftermarket heads with larger chambers that flow pretty good.
Old Jun 20, 2007 | 04:02 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
What heads does it have on it now?
Personally, I'd go with flat top pistons - if the heads on it now are decent. Cheaper than new good heads. And, as already stated, there aren't any good 76cc factory heads.
Old Jun 20, 2007 | 04:05 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
Re: 76cc heads
no truck vortec heads were 76cc ?? or swirl port/fastburn heads?
none ?
hmmmm..
on mortec some are not listed as to what CC the chambers are
Old Jun 20, 2007 | 04:25 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: 76cc heads
no vortec head is 76cc stock nor fastburn... why the hell would you even look at swirlport
never heard of a circle track allowing 383s normally they allow like 357s or so
but if it was a circle track engine then it should be pretty well set up
Old Jun 20, 2007 | 06:25 PM
chesterfield's Avatar
Car: Pontiac
Re: 76cc heads
http://www.chevymania.com/partsid/pa...p=head&block=S has 76cc 87-up listed. Offhand I'd look into 87 carbed Caprice 350 and carbed 350 trucks.
Old Jun 21, 2007 | 12:54 AM
five7kid's Avatar
If they are 76cc chamber heads, which I doubt (mortec.com doesn't list chamber cc's for those casting #'s), they certainly would be swirlies. Not the best thing to do to a hyper'd engine, but may not be a bad move for a 4x4 - if the cam is replaced as well.
Old Jun 21, 2007 | 06:51 AM
Car: Pontiac
Re: 76cc heads
Originally Posted by five7kid
If they are 76cc chamber heads, which I doubt.....
I have a book titled Chevrolet Small Block V8 Interchange Manual (which I have no opinion on its accuracy) It lists a 1987 carbed 350 as having 8.2:1 compression ratio. If this is correct it would suggest to me that the heads could be 76cc. A Chiltons 87-up truck manual may have low compression ratio carbed 350s listed.
Old Jun 21, 2007 | 11:22 AM
johnsonm's Avatar
Car: 86 Firebird
Engine: LG4 feedback controlled 350
Transmission: used to be T5 now T56
Re: 76cc heads
Just thinking out loud...
But couldn't you use peremeter bolt valve cover heads, get some el cheapo valve covers and modify the center bolt holes (use little wedges or something) on the intake? I've seen the little wedges before. Like the opposite process for using an old intake on new heads.
If this is retarded, slap me.
Old Jun 21, 2007 | 01:10 PM
five7kid's Avatar
Re: 76cc heads
Could be. Dished pistons is the other way to achieve that low CR, and the factory was going more dished in those days.
The only swirlies I've had off were 305's, which as you might expect were small chamber, so if the '87-ish truck heads were larger chamber, that would be new info in these parts.
It would be good info to get nailed down. Anyone here actually cc'd those heads?
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
