Car smells when I start it
Old Jun 19, 2007 | 08:05 PM
3rdHXCGen's Avatar
I was told it could be a fuel pressure regulator. Anyone have a similar problem or know what it could be?
Thanks in advance.
Old Jun 19, 2007 | 08:36 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Re: Car smells when I start it
How bad does it smell.... Even brand new cars smell horrible when they are first started. The convertor does not work until it is heated up.
If you are running rich it will smell worse on startup. A rich condition can be caused by a bad FPR. Check the fuel pressure at idle.
Old Jun 20, 2007 | 06:58 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Smells like what? French fries? Supposedly there is an engine out there that runs on used fry oil.
Seriously though we need more info to better help you out.
Old Jun 20, 2007 | 12:11 PM
3rdHXCGen's Avatar
Srry I guess I should have given a better description. Ok soo when i start my car, there is no smell (a little bit of smoke but no smell). However once the engine gets a little warm say 160 I get this really bad almost burning hair/rotten egg kid of smell (its not pleasant).
At First I just thought it was because my stupid friend Curtis decided he wanted to change my Thermostat bc hes a master mechanic but didnt drain the radiator or even have a bucket handy to catch excess coolent soo my engine was drowned in coolent but, that was 2-3 weeks ago and Im thinking thats not the problem anymore.
That engine that smells like french fries is a Biodiesel engine they run off of vegitable oil. Thanks for the help you guys.
Old Jun 20, 2007 | 02:16 PM
Cat59's Avatar
Car: '87 IROC Z w/43,000 miles
Engine: 305 F code motor
Transmission: 4 speed auto
Wild guess? Catalytic Converter?!
Old Jun 20, 2007 | 06:26 PM
TREK's Avatar
Car: 1979 vette
Transmission: th350
I believe we have a winner!!!
Old Jun 20, 2007 | 07:33 PM
3rdHXCGen's Avatar
If thats it im gonna feel like a dumb @$$ bc I completely skipped over it and thought no the cats fine... Is there anyway to check if thats what it is or will I just have to buy a new one and see if it stops?
thanks for the help
Old Jun 22, 2007 | 10:01 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Don't know about a check. There is an exhaust flow test but that'll only show a restriction.
But typically the sulfur smell (rotten eggs) is the cat. Never known it to be anything else.
Old Jun 22, 2007 | 04:35 PM
el_muerte's Avatar
Car: '87 Z-28
Engine: LT1-topped 400
could be something simple like some plastic or rubber on your exhaust manifold... heats up and starts melting. quick and easy thing to check.
Old Jun 22, 2007 | 05:51 PM
hung4wheeler's Avatar
Car: 87z28
Engine: 70 LT1
Transmission: 350 TURBO BUILT BY B&M
Axle/Gears: 12 BOLT POSI
check your cat again///// ?if you did check your how did you check it?
Old Nov 5, 2010 | 10:46 PM
1991TAGTA's Avatar
Car: currently looking for a 1991 TA GTA
I replaced my cat but still have the smell.
It started when I replaced My distributor cap and rotor. new wireset new spark plugs new map sensor new ignition control module. so idk wat might be the problem. Any help?
Old Nov 5, 2010 | 10:50 PM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
run a fuel system cleaner, the ones that cost more than a few dollars and use the appropriate amount of gas when using the product... I usually use techron fuel system cleaner or slick 50 fuel system treatment, if that doesn't cure the problem then you may be in for a new CAT....
Old Nov 5, 2010 | 11:01 PM
1991TAGTA's Avatar
I am currently using the fuel system cleaner. Im about half a tank done with it. My cat is new
bryan623
Mar 22, 2021 06:43 PM
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
L98GTA87
Aug 5, 2015 11:02 PM
