hmmmm i thought i was done
Old Jul 1, 2007 | 06:37 AM
MattSloc's Avatar
Car: 1986 Camaro Iroc-z
Transmission: 700r4 w/ custom shift kit
i put new heads and all new gaskets on my engine to fix a head gasket. but the tailpipes are still blowing some smoke..its white...but see when me and my friend were taking off the heads some antifreeze got into the exhaust...would it show that much..? the car doesnt smoke until its been running for a while
Old Jul 3, 2007 | 04:52 AM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
Re: hmmmm i thought i was done
yeah if alot of water got in the exhaust then yeah it could still be smoking off the water
i would drive it and keep an eye on water level and the oil for moisture collecting on the underside of the cap
if theres alot of water in the pipe then it could possibly take a long time several days or more to get it all out from the exhaust heat alone
hoew bad was it burning/leaking water ?
weve done alot of head gasket jobs due to water burning and have seen some crazy ones where the mufflers were full of water, lots of white smoke after we were done with the gasket replacements even though they werent burning water anymore
it happens.,
we confirm the repair with a radiator pressure tester tool that we have
i would try and find one of these pressure tools and pump it up and make sure the cooling system holds pressure for a few minutes with it
its only 15 PSI
so...
good luck
Elephantismo
Feb 13, 2019 12:51 AM
David Frans
Oct 31, 2015 08:12 PM
tmellott89
Oct 14, 2015 02:06 PM
Damon
Sep 26, 2015 04:29 PM
IROCZ1989
Sep 4, 2015 11:54 AM
