Is there a way to tell if a 350 is a 2 bolt or 4 bolt without pulling the pan off?
Old Jul 5, 2007 | 08:28 AM
Praetorian27's Avatar
Car: 82 Z28
Engine: 350 bored .030 over w/ 6-71 Weiand
Transmission: Turbo 400
Axle/Gears: Moser 9" w/ 4.56 gears
Is there some way to tell by the VIN number on the block? I have an opportunity to get a free 350, but don't know if it is a 2 or 4 bolt main.
Old Jul 5, 2007 | 08:30 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: Is there a way to tell if a 350 is a 2 bolt or 4 bolt without pulling the pan off
Yes. Block numbers.
I believe the site is www.mortec.com
Old Jul 5, 2007 | 11:13 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
No
Old Jul 5, 2007 | 11:38 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
X-ray glasses.
Old Jul 5, 2007 | 12:20 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Guys, why you pulling the guys leg.
Ok, here's what you do:
1.Go get a bucket of KFC, get home and lay out a blood red carpet in front of the sacrificing altar.
2. Burn aforementioned chicken in the brazier while chanting your devotion to the Dark Side.
3.Stand on your head and mutter some Black Sabbath backwards while breathing in some fumes of burning oil.
4. Go shoot the neighbor's cat with a nail gun and then hang the carcass from the back bumper.
5. Hop on one leg ten times, then go like this, spin around. Stop! Double take three times. One, two three. Theeeen PELVIC THRUST. Whoooo, Whooooooo. Stop on your right foot, DON'T FORGET IT! Now it's time to bring it around town. Bring-it-a-round-town. Then you do this, then this, and this, then this, then that, then this and that, and then--
6. Grab the casting numbers off the back of the block and look them up.
Old Jul 5, 2007 | 12:27 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Casting numbers won't tell you much. The same castings were used to produce 2 and 4 bolt blocks, only the machining was different.
If you don't care enough to pull the pan off and look, then you don't care.
Old Jul 5, 2007 | 07:16 PM
Damon's Avatar
No.
I have personal experience with 2 blocks, identical casting numbers, but one was 2-bolt, one was 4-bolt.
Factory blocks are like a box of chocolates..... you neva know what you gonna git.
Old Jul 5, 2007 | 10:30 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
yep, pull the pan, because you can never know for sure until you do
sometimes the stamping suffix code tells you, but not always
usually if it was a truck block then it was 4 bolt, if the casting code says 2 or 4 bolt
but its not for certain every time
youre better off with a splayed 4 bolt, or a 2 bolt
over a factory 4 bolt
if thats what youre getting at
good luck
355tpipickup
Aug 25, 2015 12:54 AM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
mizz0313
Aug 12, 2015 06:45 AM
gwade12
Aug 8, 2015 08:17 AM
Amillionoh7
Aug 7, 2015 01:24 PM
