Car idling crazy!!!
Old Jul 7, 2007 | 07:28 AM
creque2's Avatar
Car idling crazy!!!
Whats up guys? I have and 1989 Z28 camaro with a 350 TPI. I have a random idling problem that I just can't seem to get straight. I have replaced my IAC motor,thoroughly cleaned out the throttle body and set up the idle according to the instuctions on the site. My problem is for some reason the car will randomly start to idle about 2000 rpm and won't come down. Or it will have a hard time starting and won't idle at all. I end up having to remove my IAC and reset it manually and then it will appear to work fine for a few days and then do the same thing over again. It did the same thing with my old IAC so I just replaced it with no change with the results. I do not have a SES light or anything and have no idea where to go next. Any suggestions on what to check next would be greatly appreciated!!!!
Old Jul 7, 2007 | 09:37 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Re: Car idling crazy!!!
Originally Posted by creque2
... Any suggestions on what to check next would be greatly appreciated!!!!
Plug off the power brake booster and drive it a while using the "power-leg" brakes.
A vacuum leak probem in the booster will cause a high idle.
Old Jul 7, 2007 | 10:56 PM
creque2's Avatar
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
Thanks,
I will try it and let you know.
Old Jul 8, 2007 | 12:21 PM
creque2's Avatar
Checked it with no results....any other suggestions? Car seem to take a long time to start sometimes also.
Old Jul 9, 2007 | 02:05 PM
RodsRideSS's Avatar
Car: 87 Monte Carlo SS
Engine: Tweaked out 350
Transmission: tweaked 200r4
Check the EGR type...Some are run by exhaust back pressure and cause idle problems,..which means taking a look at the cat for damage or plugged.
Old Jul 9, 2007 | 10:50 PM
creque2's Avatar
I see. I replaced it already with a GM one about 2 months ago. I will check the cat also.
specialized
Jun 18, 2022 09:26 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Wade787b
Sep 29, 2015 01:15 PM
kyleb24
Aug 15, 2015 08:24 AM
