88 iroc camaro 350tpi getting to much gas?
Old Jul 8, 2007 | 02:49 PM
alpine247's Avatar
Car: 1988 IROC-Z
Axle/Gears: 2.77 posi stock
I just got the car today,pick it up for 500 bucks.The car will start but it is flooding its *** off.The person i got it from said he put mustangs injectors in but also he said there was use.But idk what it is none off the guages work so i cant get any codes off. I can make a video showing whats it doing if needed.Thanks Tony
Old Jul 8, 2007 | 06:41 PM
alpine247's Avatar
Car: 1988 IROC-Z
Re: 88 iroc camaro 350tpi getting to much gas?
any input?
Old Jul 8, 2007 | 06:49 PM
2tonedmaro89's Avatar
Car: '91 RS
Engine: 5.0L gross *** tbi
i'd suggest throwing in some stock injectors and seing if it changes at all
Old Jul 8, 2007 | 08:00 PM
alpine247's Avatar
Car: 1988 IROC-Z
the injectors are in it are the same psi as the stock so basically it is stock..would the fuel pressure regulator cause this?
Old Jul 8, 2007 | 08:43 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
FORD rates them differently than GM ... a 19 lb ford maybe be closer 20 a 21lb GM .... The constant needs to be changed in the prom ( might solve it )
Old Jul 8, 2007 | 09:07 PM
alpine247's Avatar
Car: 1988 IROC-Z
ok,what esle could cause this problem.i would make a video but the car run out of gas lol.
Old Jul 8, 2007 | 10:35 PM
alpine247's Avatar
Car: 1988 IROC-Z
aight i went out and fix my guages,everything works except for the tach/oil and replace the blown bulbs.i hook up a Gm code reader but i still get nothing from the light?would that be the ecm going bad causing the flooding problem.
Old Jul 9, 2007 | 08:48 AM
alpine247's Avatar
Car: 1988 IROC-Z
bump to help my as* plz
Old Jul 9, 2007 | 10:22 AM
alpine247's Avatar
Car: 1988 IROC-Z
aight i finally got my service eng light to work.i put 4g of gas in it crack it up run 90% better then before it ran out of gas,but still had black smoke coming out the exhaust.anyways i got a code 36 whats that mass air flow sensor.the book say mass air burn off or something.where is that located
92camaroJoe
Jul 29, 2023 07:57 PM
BewleyBizzIROC
Sep 7, 2015 08:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 11, 2015 03:17 PM
