Plug wires 7 or 8mm?
Old Jul 9, 2007 | 12:33 PM
goalieforlife's Avatar
Car: 1991 Pontiac Trans Am GTA
Engine: V8 305
Transmission: Automatic Transmission
What do you guys recommend 7 or 8mm? What brands do you guys prefer?
Old Jul 9, 2007 | 01:20 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Plug wires 7 or 8mm?
I like the Canadian tire shelf stuff. I think it's Bosch, 7mm? They're cheap (especially when on sale) and carry a lifetime guarantee. I keep burning them on headers, I keep getting new sets.
Old Jul 9, 2007 | 03:17 PM
8mm is stock.
I prefer Taylor Spiro-Pro ones such as these. They come in other colors too; red, blue, yellow, even lime green and hot pink.
Old Jul 9, 2007 | 10:48 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Uhm... 7mm is stock, my friend.
We use the Borg Warner Select part number CH8833. Its made for an 87-95 Chevy truck. They're all 8mm wires, and they have 90 degree boots for use with headers. The resistance is some of lowest I've seen, and the price is half that of "performance" wires that have twice the resistance.
Old Jul 10, 2007 | 08:38 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Yep, 7mm is stock.
I've never had problems with holley wires.
Right now i'm trying Megafire (I think).
You don't really need to go to an 8mm wire unless you're running some kind of powerful aftermarket ignition system.
Old Jul 10, 2007 | 05:47 PM
88camarosc350's Avatar
Car: 88 Firebird formula 350
Engine: Tpi 350
Transmission: 700-r4
8mm, it can only help.
Old Jul 10, 2007 | 07:46 PM
jonmark1985's Avatar
Car: 89' Pontiac Firebird
Engine: L03 carb Ported #87s new shortblock
Axle/Gears: 2.73 open
Ah man if you gonna give him that advice you might as well tell him to run solid cores wires and a mag.
Old Jul 10, 2007 | 08:23 PM
Sonix's Avatar
Car: 1982 Trans-Am
Yea, you might want to back up your advice with some logic eh? It's more motivating if there's some reasoning behind it.
Hey Kevin, that's good to know about the BW ones. As usual with the high performance world, sometimes the stock stuff is as good, or better, and half the price! I'm going to keep this in mind.
Old Jul 10, 2007 | 11:09 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
I switched to 8mm MSD wires when I got a new distributer cap, coil and rotor. I haven't noticed any difference but the red wires once you run them through a loom look sweet.
Old Jul 10, 2007 | 11:18 PM
Kevin91Z's Avatar
Just dont touch the distributor when the engine is running with those MSD wires. You'll get a nasty shock. That only happens with those wires.
Old Jul 11, 2007 | 07:12 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I've never been zapped with my MSD wires. I also run an MSD distributor and an MSD HVC II coil which puts out 2 amps of power. Typical stock coil puts out around an amp. If I ever get zapped, it would be enough to knock my back on my butt.
Old Jul 11, 2007 | 06:35 PM
Check for splits in your wires.
Old Jul 11, 2007 | 06:58 PM
Engine: V8 305
My car is pretty stock at the moment so I guess the 7mm will do. However the 8mm are the same price as the 7mm... I was looking at these from summit, let me know what u think.. the first is the 8mm and the second link is the 7mm http://store.summitracing.com/partdetail.asp?autofilter=1∂=SPL%2DWS8000&N=700+4294756594+400260+4294908153+4294901635+4294840138+115&autoview=sku
http://store.summitracing.com/partdetail.asp?autofilter=1∂=SPL%2DWS8511&N=700+4294756594+400260+4294908153+4294901635+4294840138+115&autoview=sku
pretty much the same thing except for the size.
The 8mm are for the older models, but I don't think it makes much difference.
Last edited by goalieforlife; Jul 11, 2007 at 07:00 PM. Reason: Automerged Doublepost
Old Jul 11, 2007 | 07:55 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Size isn't the only factor. A low resistance wire means more spark energy can reach the plug. In a typical street engine, any wire set will do. Because I run alcohol, I want as much spark energy to the plugs to keep them lit. All the fuel that gets dumped into the engine can extinguish the plug.
You can have a low resistance 7mm wire that are better than high resistance 8mm wires. Accell also makes a 8.8mm wires and some very high end wires are 9mm. Some of the wire looms can't hold the large diameter wires.
Old Jul 11, 2007 | 08:54 PM
84TranzAm's Avatar
Car: 84 TA Black/ Gold
Engine: 383 With Vortec Heads
Transmission: 700 R4 Lvl2 Performabuilt 9.5 Vert
Axle/Gears: Moser 9" with 3.70
LOL , I have the same set up and I thought wow I never been lifted by an ignition system like this before. Playing under the hood and I shorted something out I forget now it happened so quick and the shock was so much I forgot what I did .
Old Jul 12, 2007 | 12:38 AM
Kevin91Z's Avatar
On a brand new set? This is on three different sets of MSD wires on three different cars. I've stayed away from them since and just went with the Borg Warner wires I mentioned. And it was only at the distributor. Touching the wires anywhere else was no problems.
Old Jul 12, 2007 | 07:08 AM
84TranzAm's Avatar
I never run msd before but this time I went with msd everything and I have had my hands all over the wires when setting up the timing and I never got hit with a shock ounce. I was so impresed because with my accel wires I was afraid LOL.
eightsixseven
Dec 16, 2024 01:50 PM
Thornburg
Aug 30, 2015 08:05 AM
g.l.mos
Aug 22, 2015 12:02 AM
djmarch
Aug 19, 2015 12:07 PM
