my iroc takes too long to start.....
Old Jul 11, 2007 | 12:18 PM
super flash's Avatar
Car: 84 camaro iroc
every morning i struggle with this bastard. it cranks but wonnt start. then i pump it and it kinda but doesnt start. then i pump more and after more cranking it starts. takes about 20secs of starter cranking. wtf?!? afterwards its fine. ill turn it off and minutes later itll start. its a TPI engine.
Old Jul 11, 2007 | 12:25 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Pumping the accelerator pedal doesn't do anything on a TPI engine.
What engine and year are we talking about here? A little information goes a long way.
Old Jul 11, 2007 | 05:32 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: my iroc takes too long to start.....
More info is definitely needed.
Sounds like you really need to check your fuel pressure though.
Old Jul 11, 2007 | 05:49 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
maybe you should try cycling the key back and forth first. This sounds like a dead/dying fuel pump or pressure regulator.
Old Jul 12, 2007 | 07:29 AM
Car: 84 camaro iroc
well, i dont know if this makes sense but its an 84 with a TPI 350.
Old Jul 12, 2007 | 10:11 AM
five7kid's Avatar
There was no EFI offered from the factory in 1984, and no 350 offered before 1987. So, if it is TPI and a 350, somebody swapped it in there.
Which means, there is a high probability your problem is related to something that was not done properly in the swap. Like the timed relay that turns on the pump when the ignition is turned on. Or a proper fuel pump.
Old Jul 12, 2007 | 06:08 PM
xpndbl3's Avatar
Car: 1984 Z28
got a pic of the motor? I see you're from the chicago area, if you're on the southside stop by and I'll take a look at it.
Old Jul 12, 2007 | 10:27 PM
Car: 84 camaro iroc
that or the car was retagged. well the car used to sart fine before. sometimes even after weeks of not movin it it started with it even turning twice. later the block cracked thas when shiit started going downhill. i got the block replaced by an alley mechanic so i dont know if he didnt do something right.
Old Jul 13, 2007 | 03:52 PM
Car: 84 camaro iroc
are you a mechanic? how far south?
Old Jul 19, 2007 | 07:30 PM
Car: 84 camaro iroc
hello?
Old Jul 20, 2007 | 12:19 AM
xpndbl3's Avatar
Car: 1984 Z28
hop on the chicago forum down at the bottom of the messageboard and we can try to help you out. I do all my own work on these cars, built the one in my sig myself and my buddy owns a shop also. We're around tinley park, orland area.
Old Jul 20, 2007 | 06:55 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
There's a Chicago forum???
Old Jul 20, 2007 | 10:31 PM
djtricia's Avatar
Car: 1986 Z-28
Under the Midwest Boards on this site?
Frozer!!!
Jan 19, 2024 04:55 PM
bamaboy0323
Sep 3, 2015 06:07 AM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
jharrison5
Aug 19, 2015 05:53 PM
mustangman65_79
Aug 11, 2015 03:17 PM
