thanks for being here
Old Jul 14, 2007 | 09:42 PM
biged007's Avatar
Car: 83 camaro V/6 V/8 convert
Engine: 350 4bolt carb
Axle/Gears: 373 10 bolt
I know this is silly but I forgot were the oil sending unit is on a s/b v/8 gettimg old looked @ 3 books no help have they forgotten how to write one??? anyway did the search thing lots of hits so maybe It's not just me one more ? this is an older conv v-6 2 350 what color and loc. is the sending unit wire on an 83 camaro (idot light)
Thanks again
Biged
Old Jul 14, 2007 | 09:48 PM
Pat Hall's Avatar
Re: thanks for being here
So it's an 83 right? If so, the sending unit is probably located behind the intake manifold next to the base of the distributor, especially if it's an idiot light. Should have one wire going to it if it's just an idiot light sender. The newer V-8's, about 89-up if I remember right, have the sending unit located right above the oil filter in the side of the engine block. These are the only two places I know of that they put them.
Old Jul 14, 2007 | 10:02 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
your in luck...here's 2 pictures of where they could be....
1st one is right by the dizzy as stated above
2nd picture is right above the oil filter
right by the dizzy
Old Jul 15, 2007 | 12:34 AM
Synful's Avatar
heres a question.
the single prong connector on the top is for the gauge
the two prong connector on the side of it, or just below where it screws into is for what??
i don't see it in those pictures, but I see a two prong connector looks like the end of an electrical plug, with nothing attached to it, right below my sending unit. style is up top by distributor, like the first pic.
Old Jul 15, 2007 | 07:15 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
I'm drawing a blank here, I can't think of anything that takes a two prong connector in that vicinity...
Can you get a picture of it?
Old Jul 15, 2007 | 11:34 PM
biged007's Avatar
thanks! the mem.s are getting thru the grey matter the one @ the dist. is the one I need the 2 prong if I am not mistaking and prob. am is the cutout switch for the elec. fuel pump no oil no gas no boom. have'nt messed with these old girls in a long time but it's all comming back.
Old Jul 15, 2007 | 11:39 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It's not a cutout switch, it's a backup for the realy. The fuel pump will be perfectly content to keep running without a drop of oil in the engine, as long as the fuel pump relay still works.
Old Jul 15, 2007 | 11:50 PM
biged007's Avatar
see told ya I was prob. wrong I'll shut up till I remember moe hehe
Thanx
Biged
Old Jul 22, 2007 | 11:51 PM
biged007's Avatar
Had a good day 2 day changed out the gauge cluster finally found the #@$@#$ oil press wire for anyone thats interested it comes out of the main harness directly behind the dist redish brown with a rubber boot and offset conn. now for some fun blew the master cyl. this morning it's Sun ok no biggie pull the 1 out of the 86 Wrong!!! ttl. different than the 83 guess what the guts are ident. score 1 for the working guys
