what is this????
Old Jul 16, 2007 | 02:07 AM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
what is this????
I have no ide what this is or do i even need this vaccum?
Old Jul 16, 2007 | 02:13 AM
Synful's Avatar
Re: what is this????
yes you need it.
the line goes to a T fitting that attaches to the underside of your throttle body on one side, and other side continues on to the canister sitting in the driver's side front corner.
BTW....what are you doing to the car?
Old Jul 17, 2007 | 12:35 AM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
im replacin all the injectors. so its to the throttle body? I believe it was blocked off already on the throttle body.
Old Jul 17, 2007 | 02:18 PM
Synful's Avatar
ya if we're talking about the same thing.
the L shaped object takes a line from the EGR and a line from the underside of the TB and vapor canister.
Old Jul 18, 2007 | 03:38 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
I thynk that was taken out. lol not sure I just recently bought the car. Also where does the hose from the fuel pressure regulator go to again. I have a semi major brain fart at the moment.
Old Jul 18, 2007 | 08:16 PM
Synful's Avatar
passenger side back of the plenum
Old Jul 19, 2007 | 08:37 PM
rick89formula's Avatar
Car: 89 formula 350
Engine: 5.7L (L98)
Transmission: 700R4-(shift kit,corvette servo)
Axle/Gears: borge warner-3.27
This is actually your egr solenoid vacuum pickup. The way it is supposed to be routed is one line to the egr to open it and the other line to under the throttle-body to provide vacuum. The solenoid will use this and provide vacuum to the egr when needed. If disconnected, the egr will not work as I have found out the hard way by not passing emissions. Make sure these are all connected properly.
Old Jul 21, 2007 | 01:18 AM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
wat does the egr exactly do
