Battery corrosion?
Old Jul 16, 2007 | 04:38 PM
RS91's Avatar
Battery corrosion?
What could be causing that green corrosion on my + pole. I already change the battery with a new one but it still having that green corrosion?
Your assistance is greatly appreciated
Old Jul 16, 2007 | 04:45 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Battery corrosion?
It just happens. That's copper "rusting".
Scrub it off, dust it with baking SODA, and douse it with vinegar. Then rinse it off, and dry it.
You can get some battery grease in a little packet at the parts store, or use vaseline, or any dielectric grease sorta thing. Cover your pole, put your terminal back on, tighten it, and coat all visible metal basically.
If your + wire is old and frayed and whatnot, you may as well replace it.
Old Jul 17, 2007 | 07:39 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
This is what we do at the shop, and it does work... clean the terminals on the cables and the battery, put it all back together DRY, then spray the cable end/terminal with some 'heavy' penetrating oil - we like Fluid Film... it works great!
Old Jul 17, 2007 | 07:47 PM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
The corrosion is caused by acid seeping up the post from the battery.
Basically...listen to Sonix.
The reason that dielectric grease is a better option is that it actually will conduct electricity and prevent corrosion/rust (by preventing oxygen from getting to the metal).
Not that what Air_Adam is proposing wouldn't work...but it isn't the "ideal" thing. Kinda like using thermal paste on the ignition module...you want to use the paste, but dielectric grease works...just not as well.
HTH...
Old Jul 18, 2007 | 07:06 PM
Air_Adam's Avatar
HTH...
Sorry... should have been more clear lol... the grease is used between the terminal and clamp, the oil just on the outside of the cable clamp to keep the corrosion off it.
Falcon50
Aug 22, 2020 03:26 PM
3rd gen money
Oct 11, 2019 09:57 PM
RS Reaper
Oct 17, 2018 07:52 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
drumstixer
Sep 29, 2015 03:02 PM
