Main Caps?
Car: 1991 Camaro RS
Engine: 305 L03 TBI
Axle/Gears: 4th Gen 10 bolt posi / 3.43
Main Caps?
Just stripped down the 350, first time ever bringin a wrench to a motor. I got everything out of it, cam, crank, caps, etc. Knowing me I was bound to screw somethin' while attempting to do it right
. I got five baggies and labeled them for each cap. I got that part right, but I forgot to label the front and back of the caps
. It is a 2-bolt main motor, so is there any possible way to get new caps and convert the block to a 4-bolt main?
. It is a 2-bolt main motor, so is there any possible way to get new caps and convert the block to a 4-bolt main? Joined: Aug 2006
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Main Caps?
you can get a splayed 4 bolt kit that will do that. summit/jegs
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Main Caps?
Look for an arrow cast on your caps pointing forward.
You can get new caps, but they and the block will have to be machined. Maybe not worth it for a street engine.
Car: 1991 Camaro RS
Engine: 305 L03 TBI
Re: Main Caps?
Oh okay, I'm just making sure because I'm trying to make my motor as stout as I can. I'm not experienced so I don't know what alot of stuff is necessary or not. Thanks guys.
Re: Main Caps?
Define "as stout as I can".
About 30 seconds of patience is all it takes to fix the main cap mix-up.
For somebody that's never built a motor though, set yourself a modest goal: just get it apart, repaired, and back together, and running. Don't get all carried away with romantic-looking magazine builds or that sort of thing, it's not a good way to make your first-motor screw-ups. Get familiar with what you're doing before going too crazy on one.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Main Caps?
[ON] 9 Bolt Axles Partout
6speedIROC
16
Mar 15, 2023 08:33 PM
gta892000
Sep 16, 2015 12:37 AM
