Oil Filter adapter was loose.
Old Jul 20, 2007 | 09:46 PM
MikeT 88IROC350's Avatar
Car: 1988 IROC-Z
Transmission: 700R4 w/TransGo
Axle/Gears: BW 9-bolt w/3.73s
Well I did my annual oil change tonight on my IROC. Actually last year I didnt get to it, since the miles werent up there, and my tranny started to go last sept, so I parked it for the winter. (Tranny fixed now). Anyways when I did my oil service, I noticed that adapter that has the 2 oil cooler lines coming off it was loose. I reached up to clean the filter surface, and the adapter was loose enough to be able to rock back and forth a little. Then I grabbed the center nut/fitting, and was able to turn it by hand. Of course it was oily around the adapter, but not bad enough to drip, and I had no puddles in the garage. Of course I tightened up the center nut, and finished my oil change.
So anyone seen this happen before? Common problem? What could have happened, just a messy oil leak, or major oil failure?
Old Jul 20, 2007 | 09:50 PM
RITTER's Avatar
Car: 1983 Buick Regal
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
Re: Oil Filter adapter was loose.
not sure if it relates, but I work at a Jiffy Lube and we see a lot of the oil filter spindles loose, and they are always hand loose.
Old Jul 22, 2007 | 08:09 PM
Car: 1988 IROC-Z
Sure it relates. Just that my filter itself was tight, I had to use a filter wrench to take it off. I wonder how the spindle nut gets loose? Maybe it loosens up as undo the filter? Maybe I tighten filter too much, and the center nut loosens up as I undo the filter?
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
89 formula TPI
Sep 7, 2015 11:06 AM
middian
Sep 5, 2015 01:42 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
