Missing oil passage plug ???
Old Jul 21, 2007 | 03:56 PM
T-rick'srod's Avatar
Car: '88gta
Engine: 383 tpi
Axle/Gears: 3:23 australian 9 bolt posi
Hey Ya'll - I'm almost finished with the bottom end on the "tree-80-tree" and
I've got a question. Is there supposed to be an oil passage plug ( brass ?? )
under the #5 rear main cap ? I'm 99.999 percent sure that there is NOT one
under the cap. This is a one piece rear main seal block. If a plug should be there - what size ? and which side of the cap should it go ?
Any help would be greatly appreciated !!!!
" So, You're Jack Wilson."
Alan Ladd ( Shane ) - 1953
Old Jul 21, 2007 | 04:26 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Missing oil passage plug ???
Yes, there's a 1/2" cup plug underneath the rear main. If you left it out, all your oil will be bypassing the oil filter and circulating through your engine completely unfiltered.
Old Jul 22, 2007 | 11:50 AM
Vader's Avatar
Old Sep 4, 2008 | 01:06 AM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
Its the Darker of the two that is the plug correct?
Old Sep 4, 2008 | 01:23 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
No, the darker one is the rear main cap bolt hole. The plug is the shiny cup in the other hole.
Old Sep 4, 2008 | 05:55 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
and it should be driven in to precisely that depth!
Old Sep 5, 2008 | 09:21 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
VERY, VERRY important! Too shallow, or too deep and no oil to the bearings... &=not good.
Old Sep 5, 2008 | 11:19 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
In practice though it's nearly impossible to screw up the depth. The diameter of the bore changes so you can't drive it too far. As long as you don't leave it so far up that it's occluding the cross drilled hole you're fine.
eightsixseven
Dec 16, 2024 01:50 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Navy8125
Aug 21, 2015 09:32 AM
bamaboy0323
Aug 15, 2015 07:20 AM
Exxon Limited
Aug 9, 2015 08:13 PM
