Can a 3rd Gen's Engine Cradle be dropped like a 4th Gens?
Car: 91 RS/ 99 T/A/ 72 Vette/ 02 Z28
Engine: LSx/ Dart400
Transmission: M6/ M6/ TH400/ 4L60E
Axle/Gears: 4.10's / 3.08/ 2.73
On 4th Gen's it's possible to drop the K-member and engine all at once as a unit after the wiring harness etc is disconnected. Can a 3rd Gen have the engine pulled this way?
I would appreciate input.
Thanks.
Thanks.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Can a 3rd Gen's Engine Cradle be dropped like a 4th Gens?
Sort of, but in a thirdgen its easier to pull the engine out from the top.
I understand that but when, I do the LS1/A4 swap, the car will be getting a new K-member, new struts and new springs. All of that stuff is being replaced anyway. The brakes front and rear are being switched over to an LS1 set up. The rear end will also be replaced.
For my application, would it be worth dropping the cradle?
I agree for engine only it's a waste of time.
1992rs/ss
16
Jan 28, 2016 09:58 PM
