engine knock
Old Jul 26, 2007 | 11:43 PM
Black89TransAm's Avatar
Car: 89 Trans Am, 84 Firebird
Engine: 305 TBI
Transmission: 700 R4
engine knock
engine starts up fine, and runs fine, and my oil pressure gauge works, but when the car heats up the oil pressure gauge stops working, and when i hit the gas, it makes a strange knocking sound, also if i sit at a light, or just have it idle for a little bit, it puts out a cloud of white smoke
Old Jul 27, 2007 | 12:14 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Sounds like the coolant is getting into places it shouldn't be.
Old Jul 27, 2007 | 12:23 AM
Engine: 305 TBI
Re: engine knock
makes sense, been having problems with my radiator, and just replaced my water pump, how do you check?
Old Jul 27, 2007 | 01:17 AM
spina74's Avatar
Car: 01 Trans Am Ws6, 92 Camaro Rs
Engine: 6.0, 305
Transmission: T56,700R4
Axle/Gears: 3.90 9", 2.73 10 bolt
Re: engine knock
drain the oil...if its watery then you had coolant in it
Old Jul 27, 2007 | 01:49 AM
Engine: 305 TBI
Re: engine knock
just drained it, no water
Old Jul 27, 2007 | 02:00 AM
spina74's Avatar
Engine: 6.0, 305
Re: engine knock
there could be the possiblity that the head gaskets are going bad and the coolant is leaking into the cylinder and burning up before it gets into the oil.
Old Jul 27, 2007 | 02:03 AM
Engine: 305 TBI
Re: engine knock
well i know something is leaking onto the engine, because i get smoke from there after she warms up, and i am losing both coolant and oil, and im really tired of working on the car myself, what do you suggest i tell the people at the shop?
Old Jul 27, 2007 | 12:35 PM
spina74's Avatar
Engine: 6.0, 305
Re: engine knock
Just tell them you think your burning up oil and coolant but you cant figure out where its leaking from.
Old Jul 28, 2007 | 04:14 PM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Re: engine knock
Originally Posted by Black89TransAm
... what do you suggest i tell the people at the shop?
"Hi, this engine has had it, what would it cost to put in a 383 with a 4-barrel?"
But that is only a suggestion...
Old Jul 29, 2007 | 01:40 AM
Engine: 305 TBI
Re: engine knock
you have no idea how much i would love to tell them that but i damn sure dont have that kinda of money
Old Jul 29, 2007 | 02:18 AM
parks911's Avatar
Car: 91 Camaro RS
Engine: 350 Police with some MINOR modifica
Transmission: kitted 700R4 & vette servo
Re: engine knock
Now maybe someone can explain my knock.
3 weeks ago it sounded like a rod was getting ready to break thru the block so I parked the car.
Last weekend I had to move it & no knock. let it sit & idle, no knock. took it down the highway at 80 mph & no knock.
Old Jul 29, 2007 | 08:36 AM
Engine: 350 4BBL
Re: engine knock
Originally Posted by parks911
...Last weekend I had to move it & no knock. let it sit & idle, no knock. took it down the highway at 80 mph & no knock.
It sounds like a piece of trash was trapped in a lifter causing it to collapse and later found its way out. Or a chunk of carbon was stuck on top of a piston and letting it sit made it soften and it went out. Bottom end knocks don't "go away".
italiano67
Dec 11, 2016 09:21 AM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
gwade12
Aug 8, 2015 08:17 AM
