HELP! 92 Firebird lost brakes + electrical fire!!!
Old Jul 28, 2007 | 08:14 AM
EnglishFirebird's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.1 v6
Transmission: Automatic
Old Jul 28, 2007 | 10:00 AM
Engine: 3.1 v6
Old Jul 28, 2007 | 11:04 AM
89N10GTA's Avatar
Car: 1989 GTA
Engine: 355 with Super Ram
Axle/Gears: 3.73 10 bolt with a True-trac
Re: HELP! 92 Firebird lost brakes + electrical fire!!!
it would be a lot easier to help if we knew what wire it was. if you can get some pictures up we might be able to help.
Old Jul 28, 2007 | 11:13 AM
Engine: 3.1 v6
Old Jul 28, 2007 | 12:49 PM
Engine: 3.1 v6
Old Jul 28, 2007 | 01:47 PM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
As for the Handbrake.. This a manual wire system that you will have to buy the cabling and replace.. It sounds like you have a variety of problems going on.. You stated that you lost brakes and power steering..
These are 2 different system entirely..
1. The steering uses a power steering pump and gear box.. If you don't have power steering, Check your Belts, Fluid, P/S hoses, gearbox ..
2. If you don't have brakes.. There are alot of possibilities.. Hmmm, Fluid, Vacuum Lines, Power Booster, Brake Lines, Calipers or Drums, Reservoir, Proportioning valve.
Old Jul 28, 2007 | 01:54 PM
ibmtech's Avatar
Car: 1987 IROC-Z
Originally Posted by EnglishFirebird
OK, Please can anyone help me identify these parts?
http://uk.geocities.com/alexanderdou.../Top-parts.JPG
A - One of the melted hoses goes into the bottom of this
B - One of the melted hoses goes into the back of this.
Also, the braided metal cable that has melted was earthed behind this - but I can't see which component it goes to as it was melted in two places and the piece in between was loose - this may have been the source of the heat so any ideas what this went to?
http://uk.geocities.com/alexanderdou...ngine-part.JPG
Is 'C' the "Canister" referred to in my Chilton manual vacuum diagram?
Thanks, Alex
A: Is your Map Sensor. Should have a 3 wire plugin and a vacuum hose to it.
B: Appears to be the one way check valve which is usually located by the Power .Brake Booster.. But I have seen them elsewhere
C: runs off vacuum and has to control Water for the Heating system. There should be either 2 or 3 water lines that run to it. I think they are
1 goes to the Throttle Body
1 goes to the firewall for the heater core
1 the last one should go to connection by the inner fender well.
Someone correct me if I am wrong.
Old Jul 28, 2007 | 05:26 PM
Engine: 3.1 v6
Old Jul 28, 2007 | 06:22 PM
ibmtech's Avatar
Car: 1987 IROC-Z
Hmmmm.. An Air Pump switching valve.
The air switching valve directs air to the exhaust ports during cold engine operation or anytime the system is in open loop operation. It directs air to the converter beds during closed loop operation. When divert is needed, the ECM turns off the converter solenoid and causing air to be diverted to air cleaner or to atmosphere. Air is directed as such when:
I thought the one you circled looked closer to the one that directs heated water.
This is what I think they are talking about with an air pump switching valve as there is a long tube that bolts directly to the back side of the air pump
Attached Thumbnails HELP!  92 Firebird lost brakes + electrical fire!!!-air_divert_and_select_solenoids.jpg
Old Jul 28, 2007 | 06:54 PM
jimdutro's Avatar
Car: 1988 Iroc
Engine: 383 TPI
Axle/Gears: BW 9 bolt 3.27
The positive cable on my `74 El Camino grounded out and smoked the alternator, no other problems except a melted pos. cable.
Old Jul 28, 2007 | 07:14 PM
Engine: 3.1 v6
Old Jul 29, 2007 | 05:27 AM
ibmtech's Avatar
Car: 1987 IROC-Z
I will have to look at my GM Service Manuals now.. I won't be able to get to them until tomorrow morning though.
Old Jul 29, 2007 | 04:38 PM
Engine: 3.1 v6
Old Jul 29, 2007 | 05:09 PM
si_camaro's Avatar
Car: 85 Z28
Engine: LG4 modified
I topped up the brake fluid, which was full on the front part of the reservoir, and empty on the other. I could immediately see drips under the car from the mount under the engine, and when I pumped the brakes it just came out more. What's under there that could be leaking?Cheers for any help, Alex
Alex,
The rear section of the reservoir is for the front brakes, so the fact that it's empty would tie in with a front brake leakage. The engine mounts are located on the crossmember, and the brake line for the passenger side front brake runs along this crossmember before meeting the brake hose to the caliper. You can just about see the brake line in this picture, beneath the inch-thick sludge :
It may be that the hose has simply come off due to improper installation, or it could be the actual copper pipe needing replacement. You'll not know until you follow the brake line back to the leak.
For parts, give Dave Eady's a call on 01536 420201. He gets weekly shipments from the States and can probably get the MAP sensor hoses.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
Jae992
Aug 27, 2015 09:07 AM
TheExaminer
Aug 19, 2015 10:07 PM
