what are these springs good to?
Old Jul 31, 2007 | 11:26 PM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
is there any way to tell how much lift a spring can take?
well here is my question. i have trick flow 195 heads and the stock springs are good for .480 lift. i have a set of luinati springs laying around and was wondering if anyone knew what lift they are good to. they are pn LUN-73943
http://store.summitracing.com/partde...+&autoview=sku
Old Aug 1, 2007 | 12:52 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: what are these springs good to?
Under the Application tab, it says installed height is 1.750", and open height is 1.250". A little subtraction and you have a max cam lift of .500".
But a seat pressure of 108 is really weak for use with an aftermarket camshaft.
I recommend these Manley springs, 22410-16
http://store.summitracing.com/partde...w=1&N=700+150+
They're good for .550" lift and are 130lbs on the seat. I used them with my ZZ4 camshaft and am currently using them with my LT4 hot cam.
customblackbird
Aug 15, 2021 10:16 PM
sailtexas186548
Aug 26, 2015 03:32 PM
TheExaminer
Aug 25, 2015 07:34 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
