throttle body spring
Old Aug 4, 2007 | 11:49 PM
jayk2k3's Avatar
Car: 85 camaro z28
Transmission: auto to manaul
can u just buy the throttle body spring or do u have to buy the whole thing?
Old Aug 5, 2007 | 12:44 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
TPI or carb?
Old Aug 5, 2007 | 10:41 AM
jayk2k3's Avatar
Car: 85 camaro z28
Re: throttle body spring
tpi
Old Aug 7, 2007 | 10:25 PM
Rich92 RS's Avatar
Car: 86 IROC-Z, 98 Z28
Engine: 370 LSx, LS1
Transmission: T56's
Axle/Gears: 3.73, 3.42
Yeah where could you get one for a tpi? Mine idles alittle to high sometimes, and if I give it a quick little rev it will come down.
Old Aug 8, 2007 | 06:44 PM
formula_pilot's Avatar
Car: 89 Formula
Engine: LB9
Axle/Gears: 9 bolt / 3:45
If the throttle blades are sticking, the problem is likely due to a sloppy (worn) throttle shaft. Try moving the throttle shaft forward on back to see how much play you have. If there is alot of play, the blades can stick when under vacuum at idle. Putting a new spring on or adding an extra return spring is only a "band-aid" and the sticky throttle problem will be back soon (ask me how I know). The way to fix it properly is to have the shaft repaired or get another throttle body. There is a guy on ebay that does the shaft repair and also bores them out.
Street Lethal
Apr 30, 2019 12:14 PM
italiano67
Dec 11, 2016 09:21 AM
mdtoren
Aug 23, 2015 12:52 PM
86White_T/A305
Aug 17, 2015 12:16 AM
mdtoren
Aug 16, 2015 05:45 PM
