86 IROC-Z Transmission Cooler Lines
Old Aug 6, 2007 | 04:35 PM
Blue_Thunder's Avatar
Car: 1986 Chevy Iroc-Z28
Engine: 1989 TPI 350
Axle/Gears: stock 10 bolt with 2.73 gears
Are the transmission cooler line fittings on a 86 IROC-Z 700r4 brake line style fittings or are they quick disconnect fittings. I think the original owner put in the wrong trani cooler line fittings, hence why I have a large trani leak.
Old Aug 6, 2007 | 04:58 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Plain flare fittings.
Old Aug 6, 2007 | 06:23 PM
Re: 86 IROC-Z Transmission Cooler Lines
The flair fittings are leaking on my transmission cooler lines at the fittings, but mostly at where the line goes into the fitting.What is the the best way to get to these lines. I can't get access to the lines. It looks like the best way is to drop the rear crossmember to the transmission and drop the transmission about 6 inches. I just don't really want to drop the transmission.
Old Aug 6, 2007 | 11:40 PM
five7kid's Avatar
That is the best way. Just be sure to take the distributor cap off before you do it.
Old Aug 7, 2007 | 11:43 AM
Dang. I was hoping that there was an easier way. Thanks for the help
deracer
Apr 11, 2016 12:04 AM
Reddeath210
Oct 6, 2015 08:20 AM
LittleFranks
Sep 17, 2015 12:22 PM
Dialed_In
Aug 20, 2015 01:45 PM
