NEW MOTOR SWAP:PROBLEMS! HELP!
Old Aug 10, 2007 | 11:47 PM
ParkerTPIz's Avatar
i just put a rebuilt 305 in my 1991 z28 TPI.....im having abit of a problem....
everything was reconnected correctly as far as the harness and intake go....
PROBEM: i have coolant comming out of my throttle body and out of my headers; obviously there is coolant getting fed into my air intake system some how....
ANY SUGGESTIONS ON WHERE TO START DIAGNOSING????
????: could it be possible that the heads arent torqued on?, because the intake is put on absolutely perfect....i bought the motor from another person so maybe the heads werent torqued on (i know its dumb i should have checked, but obviously its too late for that...)
One of my buddies (VERTIGO Z28) said it may be the heads, he said that once the water pump caught up and started to pressure-ize the system it would start flowing coolant into the intake if the heads werent torqued on....????
I really need help on this, everything else worked out perfectly, it ran, we got it timed and just all the sudden it started flowing out of the TB and the headers....
THANKS A LOT GUYS...PM OR POST REPLY RSVP
Old Aug 11, 2007 | 12:05 AM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: NEW MOTOR SWAP:PROBLEMS! HELP!
how much coolant are we talking about? couple ounces? a gallon? if it is a very little bit i would say check the tourqe on the heads if it is in the gallons the whole engine needs to come out and be torn down
Old Aug 11, 2007 | 12:32 AM
ParkerTPIz's Avatar
i wouldnt say too much...but any at all is too much.....im just trying to figure out where to start....
heads may be warped, intake may be on wrong, heads may not be torqued??? i dunno....im just trying to figure out what i can check/test and illiminate before i go tearing down anything......
i appreciate the quick response though... can u think of anything i can start checking without having to dismantle the whole thing right away???cuz who knows it could be something very ridiculously stupid that i looked over....
thanks again, brandon
Old Aug 11, 2007 | 01:23 AM
RITTER's Avatar
Car: 1983 Buick Regal
Engine: 355
Transmission: TH350
Axle/Gears: 4.11
this is a real unfortunate situation here and I don't know if its at all possible, but is there anyway that the intake is cracked or a coolant hose is routed to a wrong spot on the intake? but then it doesn't seem like it would be coming out the headers?!? just a few suggestions
Hope you get it worked out man, I know how frustrating engine swap stuff can be, good luck
Old Aug 11, 2007 | 01:49 AM
kdxrider9262's Avatar
Car: 1987 IROC-Z Camaro
<3 not making sure everything is ok before droping motors :P
Old Aug 11, 2007 | 07:59 AM
Car: 91 RS
Engine: 350 vortec
yes great input kdx real helpful...
i am betting that if it is enough coolant for you to notice the engine needs to come back out and be torn down... as you started seeing coolant once the system was pressurized... then shut the car off so the pressure dosnt just dissappear, that water is sitting somewhere either in your oil by now or ontop of an intake valve which can lead to all kinds of very bad things...
but i am betting that as you take it apart your will be able to tell exactly where it is coming from
but to start i would look at the TPI first before anything else
Old Aug 11, 2007 | 08:03 AM
gapimpin's Avatar
Car: 1991 Pontiac Firebird
Engine: 383 LT1
Transmission: built 700r4 and fuddle 3500stall
Axle/Gears: 4th gen 3.42 auburn
coolant comming out of the throttle body???
have you tried doing the throttle body bypass?
Old Aug 11, 2007 | 12:00 PM
Car: 91 RS
Engine: 350 vortec
the fact that it has already come out the throttlebody means it is to late for the the engine has to come apart and be cleaned
Old Aug 11, 2007 | 12:36 PM
ParkerTPIz's Avatar
Weve done the TB coolant bypass..and the oil is not watered down at all.......
all these suggestions are great, dont get me wrong; thank you....but have you guys ever heard of th is happening before???
WHAT EXACTLY COULD IT BE???
Old Aug 11, 2007 | 02:11 PM
Car: 91 RS
Engine: 350 vortec
yes i have seen it and if the source of the leak isnt apparent from the outside then you will need to tear the engine down... now way around that especially if you have done the coolant bypass and made sure there was no coolant left in the TB then the only way it is getting into the TB is from the engine which means it is in the oil by now and will ruin the engine if you dont do anything about it
Old Aug 11, 2007 | 03:06 PM
ParkerTPIz's Avatar
oh yeah....were not running the engine at all....yesterday was the first day we started it....we timed it and then all of the sudden it started comming out...im def going to fix the problem i just want to narrow down my options and figure out where to start...
Old Aug 12, 2007 | 10:37 AM
ParkerTPIz's Avatar
bump!
Old Aug 14, 2007 | 12:57 AM
ParkerTPIz's Avatar
SOOOO.......i found the problem......
we ripped off the heads: we thought it was a head problem.....well we were right: someone dropped a bolt into my intake.....it got sucked into #4, dinged up the piston, and "cast" itself into my head: completely destroying the passenger side water jacket!!!!
easy fix.....but its been driving me crazy: i am a lucky SOB though....: none of the cylinders or scored!!
Old Aug 14, 2007 | 11:49 AM
ParkerTPIz's Avatar
pics of what happened
Old Aug 14, 2007 | 06:51 PM
Deeder's Avatar
Car: 1991 Camaro
Engine: 377 Carbureted
Transmission: 700R4 w/ 3000 stall
Are you sure #4 piston isn't messed up? It takes a hell of alot of force to stuff a bolt into a head casting. Post a pic of the piston if you haven't already gone nack together with it.
Old Aug 15, 2007 | 11:52 AM
Big Dave's Avatar
Car: 1992 RS Heritage
Transmission: TCI 700r4
That right there is the damndest thing I've ever seen!
hydrolic144
Sep 8, 2015 06:55 PM
greenyone
Aug 29, 2015 11:08 AM
Randomtask2
Aug 26, 2015 03:34 PM
madsv1000
Aug 20, 2015 06:45 AM
slade5612
Aug 11, 2015 07:19 PM
