Oil Gauge Problem
Old Aug 18, 2007 | 08:41 AM
mouthforcombat's Avatar
Car: '86 Iroc Z
Oil Gauge Problem
So I installed a new oil sending unit a month ago. I drove the car with the gauge working last night. Woke up this morning and the gauge is all the way up. Any ideas?
Old Aug 18, 2007 | 08:53 AM
Re: Oil Gauge Problem
Wire is off the SU
Old Aug 18, 2007 | 09:08 AM
Car: '86 Iroc Z
Sweet thanks
Old Aug 18, 2007 | 09:19 AM
Yup, should be pretty easy to take care of....
Old Aug 18, 2007 | 04:23 PM
Car: '86 Iroc Z
Well I got in my car, let it run for a few minutes and the gauge went back to how it was supposed to be, with no work required. I'm sure it will act up again... I also didn't mention the thing has sat for three years until I rebuilt the top half of the motor as the last owner was going to let it just rot away. The coolant gauge is stuck all the way up so I ran an aftermarket gauge. One time, after I replaced the gauge keep in mind, the coolant temp which was always stuck way up actually went to zero but ever since then has been stuck back up. When I'm driving my fuel gauge bounces around from a quarter to three quarters. Stupid gauges.
Old Aug 18, 2007 | 05:31 PM
Sounds like the wire is off of that one too (went to zero) but the connector is usually touching ground (reads all the way up)
Things like that just aren't hard to fix.
Old Aug 18, 2007 | 06:02 PM
Shred's Avatar
Car: 1986 Iroc-Z
Engine: 350cid crate
Transmission: t5- 5speed
Axle/Gears: stock
seems like the guages are notorious for crapping out these things. but I guess it could be any number of things like the gauge itself, the sending unit, or a fusible link. is there any way to narrow down the options? I've been driving my car for almost 2 years now without a temp gauge and oil pressure, i better fix them before it bites me in the ***
Old Aug 18, 2007 | 06:49 PM
Car: '86 Iroc Z
Screw around with the gauges, have them done somewhere, or run aftermarket.
Ghettobird52
Jul 5, 2024 11:18 PM
Reddeath210
Oct 6, 2015 08:20 AM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
Navy8125
Aug 21, 2015 09:32 AM
355sbcTPI
Aug 19, 2015 04:38 PM
