Melonized Dist Gear is .491, my dist is .427
Old Aug 20, 2007 | 08:24 PM
WhiteHawk's Avatar
Car: 1991 Firebird
Engine: 350,Dart Heads,Weiand In,Roller Cam
Transmission: 2400-Stall, 700R4 w/ Kit
Axle/Gears: 4th Gen 3.42 disc (I wish)
My distributor is from a 1990 suburban (small cap), but the shaft is a .427 and this melonized gear is for the .491 shaft. I have some ZZ4 roller camshaft, and my extensive searching concludes that I must use the melonized gear. I want to keep the computer controlled ignition (as I burn my own chips) used with this dist, does anybody have any suggestions to help me?
I am contemplating having a bushing made so I can use the gear, 31/64" O.D. 1/32" wall...
Old Aug 20, 2007 | 09:07 PM
Re: Melonized Dist Gear is .491, my dist is .427
Any factory roller compatible dist gear should work, as long as it's for the right diameter.
Look up the gear for a 96 truck, or a 92 Z28, and see what the ID is.
Old Aug 20, 2007 | 09:08 PM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Check the gear that came off the smallcap dizzy you have.. It should have a bushing in it that you can press out and reuse in the .491 gear.
Old Aug 20, 2007 | 09:19 PM
WhiteHawk's Avatar
Car: 1991 Firebird
Sofaking, aren't the factory roller cams different then ZZ4 roller cams?
Old Aug 22, 2007 | 08:59 AM
WhiteHawk's Avatar
Car: 1991 Firebird
Hey!...does anybody know what YearModel distributor has the .491 shaft and is compatible with my stock ignition system?
Old Aug 22, 2007 | 09:18 AM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Whitehawk
I know your pain. I end up ditching small diameter hat dizzy and got a full size HEI with 7 pin ignition module. Full size dizzy has a 0.491 diameter shaft and a melonized gear 10456413 from GM can be used. I have not found equivalent for 0.429 small hat dizzy. BTW, large hat dizzy can be retrofitted in place of small hat provided that you have enough working room in that area. On J-yard look for is 81-86 gm 7 pin HEI from CCC cars or trucks with no vacuum can advance. When grabbing such unit make sure to get a portion of harness (i.e mated connector pair) - a very minor harness mod (change of the connector type) is required. If you need more info - I did such swap and works just fine.
//RF
Old Aug 22, 2007 | 10:09 AM
WhiteHawk's Avatar
Car: 1991 Firebird
Originally Posted by RFmaster
Whitehawk
//RF
PM sent, I do have a big HEI cap "in stock"...not sure if I have the harness or if its CCC though, but i'm sure I can find one.
Old Aug 23, 2007 | 09:32 AM
RFmaster's Avatar
Car: 75 Beast
Large -Small hat HEI cross harness cross reference.
//RF
File Type: pdf
Old Aug 23, 2007 | 09:40 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
I'm not sofa, but, no, they're manufactured in the same manner.
Old Aug 23, 2007 | 10:30 AM
WhiteHawk's Avatar
Car: 1991 Firebird
thirdgen.org rocks my world
pjsparts
Oct 29, 2025 06:39 PM
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
earlpote
Sep 12, 2015 11:55 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
