Fel Pro 1094 Head Gasket
Old Aug 22, 2007 | 06:39 PM
Burnout91's Avatar
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
I was thinking of using the 1094 gasket (.015" compressed) rather than the 1003 gasket (.041" compressed) to gain compression when AFR 195s are installed, but was wondering about the sealing quality of the 1094. AFR says the 1094 is compatible with the aluminum heads, and should produce 10.7:1 with a stock L98 shortblock, as compared to 9.9:1 with the 1003 gasket. Anyone have any input and / or experience? Thanx!
Bill
Old Aug 22, 2007 | 06:46 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Fel Pro 1094 Head Gasket
Are you going to have enough deck clearance?
Old Aug 22, 2007 | 07:08 PM
Burnout91's Avatar
Engine: Modded L98
Don't know yet, the engine has not been disassembled.
Old Aug 23, 2007 | 05:43 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
I ran the 1094. No problems on my engine.
You are going to have to check your deck height.
Old Aug 23, 2007 | 02:07 PM
Burnout91's Avatar
Engine: Modded L98
By deck height, do you mean the distance the piston is "in the hole"?
Thanks for the replies.
Bill
Old Aug 23, 2007 | 02:09 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Yes
Old Aug 23, 2007 | 02:16 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Beat me to it.
My stock block was 24 down. I believe stock is supposed to be 25. I could've mis-measured.
Old Aug 23, 2007 | 02:20 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
.025" is nominal. Actual blocks will vary.
Old Aug 23, 2007 | 02:23 PM
Burnout91's Avatar
Engine: Modded L98
The AFR tech was calculating compression based on .020" down,"standard" on a stock L98 shortblock. I don't know how accurate that is, each engine probably varies.
Thanks again.
Bill
3rd gen money
Sep 8, 2015 11:40 PM
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
MY87LT
Aug 17, 2015 08:43 AM
