cheap horse power?
Old Aug 23, 2007 | 11:03 PM
pandemic_ratio's Avatar
Car: 1992 RS Camaro
Engine: 350 small block V8
Transmission: icky automatic
cheap horse power?
i have a 1992 rs camaro with a stock 350. it has headders and a 2 1/4 exhaust with glass packs. no air pump...thats about the extent right now im outta cash and looking to equalize my horse power to torque ratio a little bit. ive got torque like you wouldnt believe! but i have alot less pick up than i want. any ideas?
Old Aug 24, 2007 | 01:47 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: cheap horse power?
No 1992 Camaro RS came with a 350 stock. They were 305 TBI's. Only the Z28's and IROC's got the 350 with a tuned port engine.
Unless, you have a B4C police car? Those came with TPI 350's. Do you have a round air cleaner on top, or an aluminum 8-legged intake?
Old Aug 24, 2007 | 01:55 AM
Car: 1992 RS Camaro
yes i know the 305 was blown when i got the car i put the 350 in but its bone stock. oh yeah the exhaust is dual side pipes with flowtech headers...oops its TBI also.
Old Aug 24, 2007 | 07:45 AM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Although this may be TPI, some of it still applies...
https://www.thirdgen.org/forums/tpi/...free-mods.html
Old Aug 24, 2007 | 08:12 AM
WhiteHawk's Avatar
Car: 1991 Firebird
Engine: 350,Dart Heads,Weiand In,Roller Cam
Transmission: 2400-Stall, 700R4 w/ Kit
Axle/Gears: 4th Gen 3.42 disc (I wish)
Refer to the first law of thermodynamics.
Old Aug 24, 2007 | 08:45 AM
atc3434's Avatar
Car: 1986 Camaro SC
Engine: Bolt-on/cam 305
Transmission: 700R4 w/ 2500stall
Axle/Gears: 3.73 10bolt Posi
Loose the 2 1/4 inch exhaust.
Let me correct myself, 2 1/4 inch is ok if its true dual, but as a single exhaust, that would be much too small. If its just each side of the motor, thats ok. Glass packs are debatable, some think they flow pretty good, some beleive they are less than ideal, and generate a lot of turbulence in the exhaust. A good bullet style muffler on each side would sound and flow much better.
Old Aug 24, 2007 | 10:36 AM
Car: 1992 RS Camaro
it is a true dual and my glass packs are custom made...my brother owns a machine shop and fabrcates and sells his own brand (its small time/small town) i like though, they get the job done
Old Aug 24, 2007 | 01:29 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Define "stock" 350? What did you pull the 350 from? Anything on it that's not original?
There's probably much to be gained there.
Old Aug 24, 2007 | 09:29 PM
Car: 1992 RS Camaro
stock as in it came off of a 87 chevy truck and i havent changed anything but the exhaust so far. it was even TBI so it plugged right into my harness
um...i know the first law of thermodynamics but could you expand on that a little?
Last edited by pandemic_ratio; Aug 24, 2007 at 09:33 PM. Reason: Automerged Doublepost
Old Aug 25, 2007 | 11:26 PM
Kevin91Z's Avatar
Read the two tech articles entitled "Ultimate TBI mods" parts 1 and 2 and apply to your car as necessary.
italiano67
Dec 11, 2016 09:21 AM
evilstuie
Apr 14, 2016 08:52 PM
dutch930
Sep 11, 2015 06:58 AM
Chevy3shitty
Sep 1, 2015 02:10 AM
sailtexas186548
Aug 24, 2015 10:11 PM
