Cam question
Old Aug 24, 2007 | 12:34 AM
giovanniel11's Avatar
Cam question
Hi guys here's my thing. I have an 84 camaro but swapped out the 305 and had a 350 out of an 87 iroc rebuilt. I now want to change my carb. fuel pump and get a bigger cam. It's a 4 speed automatic and everything is stock what would you guys recommend.
thanks,
p.s. i'm very new to the whole engine modifying thing so I'm trying to read up and catch what I can.
Old Aug 24, 2007 | 07:35 AM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: Cam question
Unfortunately the factory 350 heads won't handle much lift, so that cuts down on your cam selection. Do a quick search and see what everyone others are running.
FYI - I know the ZZ4 & LT4 cams have too much lift for stock heads.
Hope this helps.
Old Aug 24, 2007 | 10:22 AM
Burnout91's Avatar
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
Re: Cam question
I am running the ZZ4 (ZZ3) cam on stock L98 iron heads; I used ZZ4 valve springs and "modified" valve retainers to eliminate coil bind and retainer-to-valve guide interference.
Bill
Old Aug 24, 2007 | 10:54 AM
Re: Cam question
Bill
What I was referring to by "stock heads" was the entire head... valve springs, etc. Not the physical head. You would have to upgrade your springs. etc as Burnout91 mentioned.
Old Aug 24, 2007 | 12:55 PM
stevenb's Avatar
Car: 87 camaro
Engine: 357 swap
Transmission: t5
Re: Cam question
Yeah my cam has a .510 int and exhaust lift and in order to keep it I had to upgrade to stiffer springs.
Old Aug 24, 2007 | 01:28 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Cam question
Why do you want to change your fuel pump? Is it starving at high RPMS?
What carb is on it now? It might be entirely sufficient for that HP range.
As mentioned, a decent roller cam under 215* at .050 would work well, unless you also plan on changing convertors.
Grinding the valve boss is an easy mod, don't limit yourself on the basis of lift.
beastin91rs
Oct 9, 2015 07:38 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
