Aug 24, 2007 | 09:22 PM
ok ive searched the threads long enough all i want to know is which is the best set of aluminum heads for my 383 is 200cc too much or what? keep in mind like most others on TGO im on a tight budget the cheaper the sooner you know how it is thanks brian
Reply 0
Aug 25, 2007 | 09:25 AM
Re: 383 heads
Personally I think 195cc heads are the best for a 383.
Reply 0
Aug 25, 2007 | 09:47 AM
Re: 383 heads
I run 195's on a 350, I think 195's or 200's would work great on a 383.
Reply 0
Aug 25, 2007 | 12:23 PM
Re: 383 heads
on a budget i would say the sportsman II's.. i think they are 200cc.. a friend of mine has a set and a hydro flat cam.. he has run a best of 11.70.. plenty fast for a street car.. and on a budget.. less than $1000 before shipping..
go to jegs.com (engines & components-->cylinder heads-->World-->Sportsman II) and look at the "more details" link under the sportsman II product listing.. it shows you an engine combo that produces around 480hp..
Reply 0
Aug 27, 2007 | 10:17 PM
Re: 383 heads
yeah ive heard 200cc from most ppl ive asked but will those heads fit with a TPI intake cuz i ordered the HSR for TPI heads
Reply 0
Aug 28, 2007 | 12:20 AM
Re: 383 heads
I would have to say that Airflow Research 195's are the best set of street strip heads for a 383, combined with a comp cams xtreme energy hyd roller 288 cam you can make over 500 horses, with a nice torque curve. I know you said cheap, but speaking from experience you'll save in the long run by buying the best first, instead of getting bored in year or two and wanting to improve.
Reply 0
Aug 28, 2007 | 12:43 AM
Re: 383 heads
as said any 200cc head or afr 195's cause they flow like a 210
Reply 0
Aug 28, 2007 | 12:05 PM
Re: 383 heads
I have the Dart Pro One 200cc heads on my 355 and no problems with my TPI.
Reply 0
Aug 28, 2007 | 12:09 PM
Re: 383 heads
Quote: yeah ive heard 200cc from most ppl ive asked but will those heads fit with a TPI intake cuz i ordered the HSR for TPI heads
you can run any head that takes a 1204 or 1205 gasket, most 200cc heads are a 1205, 220cc and bigger use a 1206 and the stealth ram base needs to be heavily modified to work with that
Reply 0
Aug 28, 2007 | 09:36 PM
Have you considered GM Fast Burns?
Reply 0
Aug 28, 2007 | 09:41 PM
Re: 383 heads
Quote: you can run any head that takes a 1204 or 1205 gasket, most 200cc heads are a 1205, 220cc and bigger use a 1206 and the stealth ram base needs to be heavily modified to work with that
the old bases will need heavily moddified in that new material needs added to the manifold.
the new bases from holley come with new material added already so you just need to port match which is nice.
on a mild street 383 anywhere in the 180-200 range is good. better flowing better quality 195-200 cc heads for more street strip vehicles. Most of the good brands heads in that range flow near 250 cfm or better, which is good enough for near 475-500 hp on motor, depending. 200-220 heads for hot 383's making 500hp plus i'd say.
Reply 0
Sep 7, 2007 | 05:22 PM
Re: 383 heads
so 210cc sounds the best if im gonna be driving it not just racing it i dont plan on rebuilding this motor again if i upgrade ill just get an LS1 or something (easier said than done) yeah so i do want it drivable on the weekends with out going through a tank in a day so what about these that i found off of ebay
http://cgi.ebay.com/ebaymotors/ws/eB...MEWA:IT&ih=014
Or
they both sound to good to be true for the price but im a noob to engines
Reply 0
Sep 7, 2007 | 06:48 PM
Re: 383 heads
210 might be a bit big i would stay below that...
just because a set of heads can flow enough for 500+ HP doesnt mean you will be making it at a realistic RPM
Reply 0
Sep 7, 2007 | 11:36 PM
Re: 383 heads
I'm running 215 cc Darts but then again I'm also spinning a decent cam and 14lb's of boost.
Reply 0
Sep 8, 2007 | 12:20 AM
Re: 383 heads
trust me, stay at 200cc.. anything above that, you're lookin at the need for more compression, more cam, more gear, etc.. 195-200 will be perfect for a mainly street car.. like i said, go with the sportsman II's.. i think someone on this forum was selling a pair.. do a search in the parts for sale section..
Reply 0
Sep 8, 2007 | 11:19 AM
Re: 383 heads
does anyone know if the hsr can be port matched to the World Sportsman II heads with out adding material thanks again
Reply 0
Sep 8, 2007 | 01:38 PM
Re: 383 heads
ran trick flows on my 87 with a 383 .
Reply 0
Sep 9, 2007 | 02:25 PM
Re: 383 heads
Quote: does anyone know if the hsr can be port matched to the World Sportsman II heads with out adding material thanks again
if its a new HSR within the last year i believe, it has extra material on it already and can be opened up to a 1206 port which is most 210-220 heads.
Old base style is 1205 gasket port size and most 190-200 heads are 1205 so you should beable to port match it to the heads
Reply 0
Sep 9, 2007 | 02:37 PM
Re: 383 heads
Quote: if its a new HSR within the last year i believe, it has extra material on it already and can be opened up to a 1206 port which is most 210-220 heads.
how do you tell ifyou have the new or old style? (preferably without having to remove the intake)
my hsr is almost exactly a year old
Reply 0
Sep 9, 2007 | 03:48 PM
Re: 383 heads
there will be visually alot of material around the top of the ports. HSR's have a casting date on the base manifold. mine is in 2002 lol so its old.
see this thread for info and pics of the differences
https://www.thirdgen.org/forums/alte...sr-change.html
Reply 0
Sep 10, 2007 | 09:20 AM
Re: 383 heads
Want cheap? Use a set of Vortec type head. I've seen a 383 with stock Vortec heads, 10:1 compression and a 288 XE cam put out 430 HP/460 TQ on pump gas on the dyno.
By stock heads, I mean the ports where stock, but the valve stem was machined to handle higher lift cams.
Reply 0
Sep 10, 2007 | 09:09 PM
Re: 383 heads
yeah but those wont fit the HSR i ordered or will they????
Reply 0
Sep 10, 2007 | 09:46 PM
Re: 383 heads
you could get an HSR drilled for vortecs
Reply 0
Sep 15, 2007 | 05:15 PM
Re: 383 heads
are vortecs aluminum you know as well as i do we all need to get weight of that front end
Reply 0
Sep 15, 2007 | 06:09 PM
Re: 383 heads
nope they are cast...
Reply 0
Sep 17, 2007 | 09:05 PM
Re: 383 heads
thanks everybody
Reply 0
Subscribe
