how to remove engine oil cooler block? HELP ASAP
Old Aug 26, 2007 | 03:36 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
that square block not sure if thats the oil sending unit? or just something for the oil cooler lines, either way!
im hung up on the drivers side of installing my hooker long tubes, i have the engine oil cooler lines disconnected and out of the way. However the block that they plug into (the oil sending unit??) is in the way of the header sliding in.
i already have the motor jacked up, but the piece highlighted in the picture needs to come out.
does it just thread out because if it does im screwed, theres no way i can spin that 360 degrees without unbolting hte transmission.
Old Aug 26, 2007 | 04:28 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Re: how to remove engine oil cooler block? HELP ASAP
My friend had one of those on his 88 GTA, but we didn't take if off when we sold the motor, so I am not sure how it comes off.
Old Aug 26, 2007 | 04:48 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Take a look from undreneath and it's pretty apparent how it comes out. You don't have to turn the adapter itself, just remove the center threaded part, and any bolts that go through it (I can't remember if there are any or not).
Old Aug 26, 2007 | 04:49 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
hah apparently its not apparent for me to notice that, been udner the car all day, im going to go take a look, no bolts that i could see tho
Old Aug 26, 2007 | 05:01 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
wow ya i see that now, didnt realize that would thread out, i managed to crack it with an adjustable wrench but now im just damaging the outside of the bolt part, ill get a proper sized wrench for it tommorow
thanks so much!
Old Aug 26, 2007 | 07:32 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
A big, deep 6 point socket usually works best for that. I don't remember the size offhand, though.
Old Aug 26, 2007 | 09:38 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
my adjustable said its 1 and 1/16th, gonna try and find a socket that size, not sure what that is in mm if its metric....it is a canadian car
Old Aug 27, 2007 | 12:42 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Since the small block is relatively unchanged since 1955, not many things that bolt directly to the block are Metric.
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Navy8125
Aug 21, 2015 09:32 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
3rdgenparts
Aug 8, 2015 07:09 PM
