clutch question
Old Aug 26, 2007 | 06:28 PM
w_mortell's Avatar
Car: 91 Camaro
Engine: 3.1 V6
Transmission: Automatic
Axle/Gears: stock(what could be better!!)
clutch question
hey, anyone know where to get a good clutch for my 91 v6 5 speed firebird? I am looking for dependability and price....I dont make loads of money just yet, so the wallet is usually a little thin. any one got any suggestions aside from the local parts store?
Old Aug 26, 2007 | 10:13 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: clutch question
The local parts store is your best bet. A V6 doesn't need a high performance clutch until you do a lot of high performance tweaks to it. Dependable and cheap - your local parts store. Maybe wait for a sale too.
You might be able to get away with just a friction disc ($60), then when you've got $$ burning a hole in your pocket you can spring for a high perf kit ($250)
Old Aug 27, 2007 | 02:29 PM
w_mortell's Avatar
Car: 91 Camaro
Engine: 3.1 V6
Re: clutch question
thanks. yeah, im not lookin for preformance right now, just drivability with a budget, didnt know if anyone knew like a discount place or something. How do I know if I will just be able to change my disk...this is my first 5 speed by the way, I have driven them alot, but never owned one, so i havnt had alot of experience in the clutch assy and workings of it.
Old Aug 27, 2007 | 02:41 PM
Sonix's Avatar
Car: 1982 Trans-Am
Re: clutch question
rockauto.com might be a good inexpensive bet. Compare their prices to your local parts store, after you factor in shipping from Rock auto.
First off, how do you know you even need a new clutch?
The only wear part in the clutch system is the friction disc. It's kinda like the brake pads eh? The flywheel sometimes needs to be machined (like turning the rotors). Usually people buy the kit, which comes with the friction disc, pressure plate, a throw out bearing, and the tool to install it.
If your clutch is chattering or something, you probably need to have the flywheel machined. If the clutch just engages really late, then you most likely don't have much friction disc surface left.
Old Aug 27, 2007 | 04:30 PM
w_mortell's Avatar
Car: 91 Camaro
Engine: 3.1 V6
Re: clutch question
well, see i finally got the thing running (VATS!!!) and I took it down the street and at first it slipped in second gear, but then quit and caught real good. Then I went out again after the engine had been warmed up and yes it does catch late, and it slips quite a bit and shakes violently. I mean it still moves and all, but shakes like when you let off the clutch too early, but worse. . I can even let completely off the clutch from a stop and it just slips alot...1st or R. Every gear change it slips....what do you think it is?
Old Aug 27, 2007 | 04:37 PM
Sonix's Avatar
Car: 1982 Trans-Am
Re: clutch question
I'd look under the car for loose stuff. Clutch engaging late probably means you need a new clutch, but the shaking?
-motor mounts
-tranny mount
-TA mount (loose bolts, or screwed rubber mount)
etc.
You'll need to pull the tranny to do the clutch, so you'll find out then if something else is amiss.
Old Aug 27, 2007 | 05:06 PM
w_mortell's Avatar
Car: 91 Camaro
Engine: 3.1 V6
Re: clutch question
ok, I'll crawl under there tonight...u think I will need the whole clutch kit? I know its kinda hard to diagnose it from another country, but like I said, I dont know much about manual transmissions...Thanks for all your help man, I will keep you updated incase i need some more help with it.
Old Aug 27, 2007 | 08:27 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
http://www.autopartswarehouse.com/pr...ory=clutch_kit
Figure on needing to get the flywheel refaced as well.
Old Aug 27, 2007 | 11:22 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: clutch question
is the car leaking any oil... maybe a spot right between the engine and transmission?
Old Aug 28, 2007 | 09:56 PM
w_mortell's Avatar
Car: 91 Camaro
Engine: 3.1 V6
Re: clutch question
not visibly, there is absolutely no oil on my garage floor. and the car just sits there, occasionally i fire it up, but no oil leaks or anything...does it mean it has to be the clutch when it is doing this?
Old Aug 28, 2007 | 10:04 PM
Car: 91 RS
Engine: 350 vortec
Re: clutch question
well yes the clutch would be the my first guess i only asked about oil leaks because those will often cause a clutch to seem like it is spent when there is really just oil on the friction surface... clutch is still spent but you need to fix the leak before it ruins a new clutch... just looking out for your money
Old Aug 28, 2007 | 10:09 PM
w_mortell's Avatar
Car: 91 Camaro
Engine: 3.1 V6
Re: clutch question
I think I am just going to replace the disk for now. From what I hear that should help it grab a lil more
Old Aug 28, 2007 | 10:12 PM
Car: 91 RS
Engine: 350 vortec
Re: clutch question
okay but i would take an awful close look at the flywheel while you have a chance it might need to be resurfaced... think it costs about $15-20 might be worth it if you dont like clutch chatter
Old Aug 28, 2007 | 11:25 PM
w_mortell's Avatar
Car: 91 Camaro
Engine: 3.1 V6
Re: clutch question
ok, I will do that. So, Im pretty much supposed to look for markings and wear like a break rotor? I know it wont be the exact same of course! Thanks for the advice everyone.
Old Aug 29, 2007 | 12:35 PM
five7kid's Avatar
Very similar to brake wear, actually.
I don't think I've ever replaced just the clutch disk. The pressure plate and throw-out bearing are insurance, if nothing else.
Old Aug 29, 2007 | 09:03 PM
w_mortell's Avatar
Car: 91 Camaro
Engine: 3.1 V6
Re: clutch question
alrighty...i guess it is just about as much work to do all of it. just a few more dollar bills.
Drone358
Sep 1, 2015 02:50 PM
87 camaro iroc
Aug 20, 2015 07:47 AM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
rsrmoore
Aug 7, 2015 08:44 PM
