Alum intake install -needs to be cut
Old Aug 27, 2007 | 02:53 PM
Pnormandin's Avatar
I just swapped in my race 350 for my 305 in my 84Z. The 350 has a Canadian steel intake and 2 barrel carb (mandated by the rules not by choice). I want to switch it out for edelbrock intake/carb setup i was using on the 305.
The problem is, is that when I built the motor some years back I remember having the heads, block and intake decked and I cannot remember by how much. So this mean I need to get the new intake shaved.
Do any of you know a good method for getting an accurate measurement?
I was thinking about pulling off the steel one and measuring bolt hole to hole.
Thanks for any ideas/help.
Old Aug 27, 2007 | 03:24 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Alum intake install -needs to be cut
Unless you milled everything by a lot (ie. angle milled the heads), it won't be a problem.
Old Aug 27, 2007 | 03:49 PM
Pnormandin's Avatar
So you think a standard pass would be good enough??
Old Aug 27, 2007 | 04:44 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I wouldn't think you'd need to mill it at all.
Old Aug 27, 2007 | 07:33 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
You can probably lay it on the heads with a gasket and eyeball it. See if there's an obvious gap. Perhaps try to slip in a feeler gauge?
Terrell351
Jun 13, 2021 01:13 PM
Caspar
Jun 19, 2016 11:19 PM
TheJoeY88
Aug 13, 2015 06:51 PM
bryan623
Aug 10, 2015 11:33 AM
MENINBLK
Aug 5, 2015 11:58 PM
