Timing Chain
Old Aug 28, 2007 | 01:59 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Timing Chain
Hi Everyone,
I'm getting ready to build a non-roller 383. Does anyone knows if my L98 timing cover and Cloyes True Double-Roller timing chain will fit ok on the 383?
Thanks!
Old Aug 28, 2007 | 04:18 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Timing Chain
The cover will fit, but the chain won't.
Old Aug 29, 2007 | 03:46 PM
Re: Timing Chain
Thanks Apeiron!
Old Aug 29, 2007 | 05:03 PM
Re: Timing Chain
You can get it to fit fairly easily with minor grinding.
Old Aug 30, 2007 | 07:50 AM
Re: Timing Chain
Will the chain itself not fit or will the holes not line up correctly?
What do you have to grind?
Thanks again!
Old Aug 30, 2007 | 08:25 AM
Re: Timing Chain
The chain may not fit.
It may rub on various of the little bolt bosses. They are often larger than in earlier blocks; the edge of the chain rubs on them.
It's really not a big deal, people do it all the time.
Old Aug 30, 2007 | 11:42 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Timing Chain
I was thinking that the L98 roller cam timing sprocket wouldn't fit a non roller cam, but I suppose you could get a non roller cam with the right nose on it.
Old Aug 30, 2007 | 01:11 PM
Re: Timing Chain
Well yeah, there is that; a roller timing set won't fit a non-roller cam.
Kind of hard to tell what we're mixing and matching here.
Vintageracer
Jan 10, 2020 05:33 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
MY87LT
Aug 17, 2015 08:43 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
